Hey guys I have got some scff marks on my car. Theres also a few spots which are "dirty" or brown in colour but no matter how much a sponge it, it doesn't go away. Will a clay bar do anything? Have a look at the pics. Sorry I took some tonight. If you look around the nissan badge it's a bit smudgey.
Any help would be appreciated.
Edited by pac34r
https://www.sau.com.au/forums/topic/371943-scuff-marks/
Call Antonio at Waxit.com.au 9330 2177, they have small bottles of polishes, explain to him what its for and order a bottle and a hand pad that they have in stock (much better than just a applicator).
Regards,
Mitch
https://www.sau.com.au/forums/topic/371943-scuff-marks/#findComment-5930808
I just use jiff some people say its to abbrasive but ive never had problems after uding it snd it gets off anything.
Never had problems until you continually use it and end up with no clear left its WAY to abrasive, and if you had an eye for paint you would see substantial swirls and marring where used.
NO WAY I WOULD EVER USE OR RECCOMEND USING IT ON SOMEONES CAR.
its just as cheap and ALOT better to buy Poorboys SSR1 and a hand polishing pad from Waxit so why not do it properly, dont see the point in spending so much money on a car and have your pride and joy just to skimp on proper maintinence....but thats just me maybe.
https://www.sau.com.au/forums/topic/371943-scuff-marks/#findComment-5933423
Had similar problems on the passenger sideskirt from previous owners girl friend wearing high heels and actually putting scratches on there grrr and these don't come out
Everything comes out :) you just got to know what to use and how.
I strongly suggest calling Antonio at Waxit.com.au ask about the hand polishing pads and little polish bottles and they will come out :)
Regards,
Mitch
https://www.sau.com.au/forums/topic/371943-scuff-marks/#findComment-5950975
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
