Hello,
At this time I have a Magnaflow muffler on my car. I like the muffler, but I do a lot of long distance travelling and when you are in lower rev ranges (1500-3500RPM) the exhaust is very loud. Being distance travelling there is hills
where the RPM is in that cruise range and the minute you start going up hill/increasing the accelerator the car is very loud. I have tried getting over it, but it's so loud you can't hear the radio, you end up with your ears aching and sometimes
after a while you even get a headache.
I was wondering if there was any ways to quieten this around that rev range when it's straining more or is there a better muffler, performance and sound wise out there?.
1993 R33 GTS RB25DE
Thank you.
Edited by Brendonams
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/
Heyy i had the exact same problem with my muffler, i put a silencer on it but it didnt make much difference, so i went back to my stock muffler. You could try putting a silencer on yours but my advice is to change back to a stock muffler since you are losing power by using your current muffler. Your car is a non turbo (like mine) so the engine relies on the exhaust system to create back pressure, unlike turbo models which create backpressure from the turbo. By putting the muffler on you have robbed torque from your car. Im guessing you just chucked on a straight 3 inch mufffler or straight pipe on your standard exhaust system. Thats the same mistake i did, and i got a very loud exhaust which made it unbearable to drive. If you notice on the factory muffler, there is a butterfly valve thing, which actually connect to the throttle and is kept closed to give it more back pressure, this helps the initial torque to push the car in a higher rpm, the valve then opens to give the car more power as it climbs higher in the rpm to increase peak power. But by putting a different muffler the back pressure dissapears, causing the car to use more fuel and reduce initial accleration. The only place i can think of that sells factory mufflers is Dandy exhausts, thats were i got mine done, and it doesnt cost much. Mine costed 80 dollars to do. if you want power and a nice exhaust sound, you need to spend 1100 dollars on a proper exhaust system.
Edited by Deza3000
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5930634
btw in my opinion, just stick with the factory exhaust system, cause nissan engineered it for optimum performance, and the ecu is set to work with what the car currently runs on...e.g. the standard exhaust system. If you wanna change exhaust, then change to a cold air intake aswell, then do a ecu retune/remapp so it can run better. thats goona cost ya 2-3k if you want more performance, as for power gains your looking at 25-30kw. Which is actually a fair bit and i reckon you would be able to beat a ve commodore with that much power added on ;p
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5930637
Ok, il have a look at getting a standard one, um I bought the car with the muffler on it. All i pretty much know is it has a Catback exhaust and the magnaflow muffler and it has a K&N Cold air intake.
How does the standard one sound and am I really going to get more power with a standard one? Ideas from others maybe as well?
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5930900
hmmm you sure its a cat backk?? from my experiences catbacks arent as noisy, they have more of a nice tone, If it is a cat back then i dont think the stock muffler would bolt onto that. Take it to dande exhausts and tell them your problem, they will reduce the noise for you, do you live in melbourne??
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5931005
Yeah, when I bought it the owner said it has a Catback exhaust on it, il take a photo of underneath the car tonight to see if you can tell. I live in Tasmania and i've taken it to a muffler specialist, he put another reasonator or something in it, he said there is no space for a second muffler and he said nothing else. The attachment is kind of like what I have on my car (Not exact)
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5931143
sorry bud just gonna correct you on this.
the factory muffler does not have a butterfly valve nor any sort of system that will do what you described.
what you've described is actually like what the HSV VE's "bi-modal" exhaust does, or similar to an x-force varex, which you can either control the valve manually with a remote & im pretty sure on the newer ones you can have it automatically adjust at certain RPM.
try somewhere else, there is definitely room for a centre muffler, the stock system has one so no reason why you cant have someone fit one to an aftermarket system.
i had the same issue, had a catback installed on my r34 with no centre muffler, it was horrible, i tried a couple of different exhaust shops over a weekend & the all said they can only fit a hotdog resi, so i ended up just booking it in with the guy who intially did it & he had no trouble fitting a small 8"x4" centre.
also, no chance of gaining 25-30kw from a cold air + exhaust on an N/A skyline haha
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5931185
@ lindz34, The factory r33 skyline does come with a butterfly valve which is in one of the mufflers hole. The one in the skyline isnt electronic, It is actually connected to the throttle by the silver wire, similar to the one connected to the throttle body, and as the driver pushes the throttle, the valve opens to let out more air.
will upload a pic of my factory muffler
Edited by Deza3000
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5931260
"Some" R33 do have the butterfly valve on the exhaust, must have been a factory option - I got the official Nissan factory technical manual on the R33 and some cars do have this equiped.
R32 and R34 do not have this feature
For your exhaust just buy a high flow cat and put a stock rear muffler.
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5933164
wow really?
that's cool haha
apologies for my failed attempt at correcting :P
anyway if it helps dude, i have a 2.5" cat back, small 8"x4" centre muffler & x-force varex rear oval muffler (cannons are quite a bit louder than oval shaped)
i drive on the freeway every day to & from work, sitting at 100kmph nearly the whole way & it's not an issue drone-wise, never been pulled up by the police for being too loud either.
there's a few options that the other guys have pointed out, so i guess it depends what you want, if you still want a nice sounding exhaust then go a centre muffler & if you want it to be more stock then obviously a stock rear muffler.
as for brands, my centre is a magnaflow - sounds nice.
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5933277
  • 3 weeks later...
mine is a 2.5" with a hot dog AND a resonator AND recently changed to a mild steel oval muffler - every possible thing in the world to keep it quiet ...
its still very loud ... with the last exhaust change though it took a few weeks before the car started to keep it down so im hoping this is the same thing here and it will eventually shut up.
in terms of power - think more of 2-3 kw rather than 20-30
https://www.sau.com.au/forums/topic/371957-na-r33-muffler/#findComment-5961414
