gday guys im wanting a custom twin scroll t3 with external gate low mount manifold made anyone got a website or email address for 6boost and ETM or anyone else who can make then need one soon not chasing big power just want a nice 320rwkw out of my rb30det but dont really wanna go highmount
Thanks
  • Replies 42
You seriously put "extreme turbo manifolds" into google and found nothing?
Its the 3rd result, or the 7th result for google.co.nz (ive checked as i couldnt believe 15 pages).
Same for 6boost, they are the 2nd result. Aded to that 6boost are a forum trader.
Why don't you just pickup the phone tomorrow?
The 3rd result from google.co.nz was a link to the Yellow Pages (ETM), this has their phone number on it.
Surely a $5-$10 phone call is worthwhile?
6boost website has a phone number, email address.
They are also a forum trader so you could even send them a PM :merli:
yeah i might do that im just not chasing that much power i only wanting 320rwkw max from my rb30det wat do u recommend r31nismoid ???? im on a budget thats all
Id say don't buy a china manifold :D
Either item you are chasing will work fine.
Just comes down to your budget. Remember you need to purchase a gate etc as well.
yeah i can get a 44 tial for around 300 so be happy to spend no more then 600-700 on a manifold or do u reckon i can modify a stock one to handle 320rwkw???
theres a guy in new zealand whos steam pipe manifolds look excatly the same as a well known brand and there only 380 delivered
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=320732922142&ssPageName=ADME:X:RTQ:AU:1123
looks pretty decent and got the feedback to match
i have my stock mani running 304rwkw with 3076 and 38mm gate.
just have the manifold ported.
edit, look how high that manifold sits. and it doesnt look anywhere near a 6boost etc item
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
