Rb25 Turbo Manifold Help? Need One Made
jet2nv
 Share
  • Replies 42
was that on a rb25 im looking at running my gt3582 on my rb30det :) but only want 320rwkw at a max
Why would you buy a GT35 if you only want 320rwkw?
Stock manifold on a 30DET has been proven to be a restriction by a couple of people @ the 300rwkw marker.
IMO sell the GT35, but a GT3076 and settle for 300rwkw or so. Use the stock manifold as well.
You wont get a decent manifold for $600
im tryin to sell my turbo :( i bought it brand new but my intentions have changed would gladly swap a brand new 35/40 for a 3076 plus a modded manifold
look at the manifold on the ebay link i put up
Edited by jet2nv
how much are you after for ur GT3540? and what size is the rear housing... also i seen this a while back and i can say this video convinced me + all the positive feed back I've heard about the 6boost manifolds.
ok guys ive got the hks low mount manifold now question is what turbo to get as i only want 320rwkw max but i dont want to run more hen 20psi
ANY SUGGESTIONS
i can get a gt3076 the real one for 1400-1500 brand new genuine garrett
or the gt3582 also genuine garrett brand new for the same price
any help would be great
nah i got no e85 near me and only running 555cc injectors
so the 3076 on 20psi or less using a 44mm gate hks low mount manifold usual other mods nistune ecu 040 pump on a rb30det will make 320rwkw??
so if i get a 3076 is there a certain model number or something as ive noticed theres a few different types and i want the most powerful 3076
cheers guys
anyone know what the pull is like i know the 35/40 pulls extremely hard and has traction issues
ive read through heaps of results it doesnt make sense to me how someone can make 308rwkw on 18 psi on a rb25det with a 3076
yet on a rb30det they are running 20psi with meth injection for the same power
nah twin cam 3 litre
i use to have a 28-35 aka gt3071 made 260rwkw on 18psi on my old rb25det was pretty much close to maxed out
im thinking im just goin to get a gt35/40 .82 rear and settle for 320rwkw with pretty good response full boost around 3500rpm
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
