Looking to by an ARC super induction box for a 34 GTT. i know they have gone bust, but there has got to be some around still. Anyone know of any good places to pick one up from? Ive got mates in japan if there is anything over there i can grab it from.'
Thanks
https://www.sau.com.au/forums/topic/371965-arc-super-induction-box/
thanks mate, sent him a message and he said he couldnt find any new and hes looking for any good second hand ones.
Cool!
Also try "Up Garage"
upgarage.jpg?w=500&h=333
This one was in Chibaminato, about an hour or so East of Central Tokyo.
Up Garage is basically a used, high-performance parts dealer.
http://www.upgarage.com/
i was looking at the for a while, and i saw under a mates bonnet and they look sweet! Why you say, they no good?
I'd keep the stock air box and just upgrade the panel filter to a high flow panel filter on the inside.
An ARC Air Box is similar to an Air Pod as both have exposed air / sponge filter(s) (can suck in hot air).
If you go ahead with it, I suggest you keep your stock cold air intake (the one that sits on top of your radiator, It can separate from the stock air box.).
To feed cold air to the ARC air filter.
it wont suck in hot air if you have a bonnet vent that directly feeds it fresh cold air...
It has a larger filter area than stock and is top feed, so the bonnet vent is the perfect setup for these...
My bonnet vent is dorectly above it and Ive got a flame proof tunnel connecting the bonnet to the top of the airbox...
thanks for your help mate! hopefully something turns up
Cool!
do you have any pictures of your set up bro?
75coupe bonnet will look something or similar like this:
This is the Nismo R-Tune Carbon Hood Air Feed for the R34 GTR.
When you shut the bonnet, the air feed will sit directly on top of the Nismo Air Box or any intake setup in that position.
http://www.nengun.co...carbon-hood-gtr
http://www.rhdjapan....uct-bnr34-56040
thats pretty damn nice^^^^^, but no mines just a vent on top of the fg bonnet that is right over the airbox.... I'll see what I can about photos...
found some links to purchase one for a er34 though
http://www.tunersgroup.com/Online_Store/ARC_SIB_ER34.html
http://www.ebay.com.au/itm/ARC-Super-Induction-Nissan-Skyline-R34-GTT-RB25DET-HKS-/290485168460#ht_703wt_907
http://www.tunersgro...C_SIB_ER34.html
http://www.ebay.com....60#ht_703wt_907
Oh yeah!
One hell of a sleeper mod :D
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
