Balancing Crank And Flywheel If They Are New From Nissan
Never, well......, some old BMW'S are kinda cool, like old Alfas and Fiats (althoughI would never own one), and I have a soft spot for old Bettles (punch buggies), as for the new BMW, VW and Hyundai's might be a blast on the track, I look at them like soulless tools
Standing around having photos taken on insta. (sad but true). Go to a track day, what is actually there nowadays could suprise you, you need to update your cool car in the hill radar to include VW, Hyundai, BMW etc
Hello again, I just want to tell you that i found the reason why my bnr32 is going out in right corners. I had my car tuned by a company and they fitted the Emu Classic and a new fuel pump in 2021. I checked the loom, changed the walbro fuel pump with a Deatschwerks fuel pump. None of this helped. Then I checked the fuel pressure and thought I was crazy. It was tuned with over 7 bar ( over 100psi) !!! But why? So I checked the fuel return line and saw that it was closed. That was probably also the reason why the tuner replaced the fuel pump, but he tuned the Emu with the 7 bar 🫣 The map in the emu has now been changed and evertyhing is fine.
I'm going to vote for considering going to the effort to close the lash down to the minimum. My bro-in-law got around to checking the clearances on the 3SGE in his Caldina. Was a bit fat all over. New shims at lowest allowable lash, and the car is remarkably better to drive. It appears that the increase in both total lift and duration that you get from doing this is worth a lot more than you might expect. I have been having evil (and expensive and time consuming) thoughts about doing it to mine, and I don't even think I have a problem. Not that I'd know, though.
