chris pohlman Posted July 25, 2011 Share Posted July 25, 2011 hi guys................ ive done some small research on this and have done some DIY jobs trying to eliminate problems with the pinging at high revs........ driving half throttle (normal driving) is good but when u get into high revs just pings alot i have replaced the fuel filter..........also checked spark plugs and the coil packs (splitfire coils) i also have a walbro 550hp intake fuel pump. Just trying to eliminate small jobs, could be timing but its around $1500, dont wanna spend that if its not the problem. could also be other minor ones. IE plenum gasket, injectors If anyone has fixed or known a problem let me know so i can fix the job right away. thanks guys Im driving a 93 R33 running a r34 turbo (10psi) Stock ECU, splitfire coil packs, walbro 550hp fuel pump just to name a few mods. Any ideas wold be greatly appreciate thanks chris Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/ Share on other sites More sharing options...
Rolls Posted July 25, 2011 Share Posted July 25, 2011 Could be a million things, most likely fuel related though, fuel pump > filter > injectors > fuel reg. It is likely to be one of these. Other thing is has the base timing been changed? Whatever you do stop driving it when it is pinging, you will destroy a piston/ring land very quickly. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931254 Share on other sites More sharing options...
chris pohlman Posted July 25, 2011 Author Share Posted July 25, 2011 Could be a million things, most likely fuel related though, fuel pump > filter > injectors > fuel reg. It is likely to be one of these. Other thing is has the base timing been changed? Whatever you do stop driving it when it is pinging, you will destroy a piston/ring land very quickly. i havent been thrashing it, i have posted something similar to this about a month ago, and ive been working pretty hard to find the problem, rather fix it than thrash it and bam redo an engine. im not sure about the timing, ive had the car for about 3months and the guy said he done the timing but in my mind.....he hasnt......theres no sticker on the timing cover stating otherwise........ if its fuel related then i have started with one...filter...can pick up another pump for 150. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931263 Share on other sites More sharing options...
Rolls Posted July 25, 2011 Share Posted July 25, 2011 What do you mean when you saying 'timing', as in the cam belt? If you do it yourself you don't need to sticker it, just have a look and see if it looks new, that won't cause any issues though. When I said base timing I meant the CAS. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931268 Share on other sites More sharing options...
boostn0199 Posted July 25, 2011 Share Posted July 25, 2011 Check the timing with a timing light. It will be easier to diagonse if you put it up on a dyno. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931275 Share on other sites More sharing options...
chris pohlman Posted July 25, 2011 Author Share Posted July 25, 2011 What do you mean when you saying 'timing', as in the cam belt? If you do it yourself you don't need to sticker it, just have a look and see if it looks new, that won't cause any issues though. When I said base timing I meant the CAS. i meant by the timing itself, not the CAS..... but ill check the cam belt in the next two days. how much would take cost roughly? Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931325 Share on other sites More sharing options...
chris pohlman Posted July 25, 2011 Author Share Posted July 25, 2011 Check the timing with a timing light. It will be easier to diagonse if you put it up on a dyno. been thinking about buying a timing light would be easier incase its not the timing. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931333 Share on other sites More sharing options...
The Dan Posted July 25, 2011 Share Posted July 25, 2011 +1 Check ignition timing with a light The timing belt is not going to be causing a pinging issue (it can but it won't be - unless it's about to fall off) And $1500 to do a timing belt/waterpump etc = dayam! Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931354 Share on other sites More sharing options...
Rolls Posted July 25, 2011 Share Posted July 25, 2011 (edited) i meant by the timing itself, not the CAS..... but ill check the cam belt in the next two days. how much would take cost roughly? If the timing belt is fine (it will be timing wise, might be old and need to be replaced though) and the CAS is set correctly (get a timing light and check) and you have a stock ecu then there is nothing else timing related that can be changed. Changing the timing belt (if it is old and frayed) should be $400 ish max, whoever quoted you $1500 is taking you for a ride, I think I got the water pump done as well in that 400 when I paid someone years ago. Edited July 25, 2011 by Rolls Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5931392 Share on other sites More sharing options...
chris pohlman Posted July 25, 2011 Author Share Posted July 25, 2011 thanks heaps.. yeah ill check the timing belt and CAS on thursday when i have my day off, ill keep you posted. .hrm ill look at buying a timing light, not sure where to buy one on the sunny coast but ill do some shopping, also do some quotes on getting the timing and water pump also. when i bought the car, the guy said that he didnt know about the timing belt, he had it for two years but got it serviced though..... said the coilpacks were brand new and same with the fuel pump, so i elminated them..... but not sure if i should trust his words.... ill keep this updated then Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5932506 Share on other sites More sharing options...
Rolls Posted July 25, 2011 Share Posted July 25, 2011 Go to any half decent nissan specialist and ask them to check the timing for you, I'm sure they will do it for cheap. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5932593 Share on other sites More sharing options...
chris pohlman Posted July 25, 2011 Author Share Posted July 25, 2011 i do have a nissan store down the road from me, do go there mostly all the time, but they are pretty over priced on things...... just for a plenum gasket is around $100 and i saw on some other parts site for a plenum gasket for $40. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5932938 Share on other sites More sharing options...
AngryRB Posted July 26, 2011 Share Posted July 26, 2011 maybe you should check the compression too... if its all carboned up inside it will have too much ive had the cas fully advanced before and added octane booster with no audible pinging or problems, only time it pinged was with low octane fuel, ( i dont do that anymore) just saying with a standard ECU it must run rich enough to wind the cas up a fair bit, from the 2 rb25det that ive seen after being tuned, its sits about half way. Does the car run hot?? if it were overheating it would ping pretty fast, Do you have a boost guage to make sure its not overboosting and running out of fuel? Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5932981 Share on other sites More sharing options...
chris pohlman Posted July 26, 2011 Author Share Posted July 26, 2011 maybe you should check the compression too... if its all carboned up inside it will have too much ive had the cas fully advanced before and added octane booster with no audible pinging or problems, only time it pinged was with low octane fuel, ( i dont do that anymore) just saying with a standard ECU it must run rich enough to wind the cas up a fair bit, from the 2 rb25det that ive seen after being tuned, its sits about half way. Does the car run hot?? if it were overheating it would ping pretty fast, Do you have a boost guage to make sure its not overboosting and running out of fuel? i never go below quarter of a tank of fuel always full, i do watch the boost gauge never goes past 10psi, i barely hit that mark when the noise comes, dont want to ruin the car....... and it doesnt run hot, sits on below normal tempt. does it in the cold aswell, took it out for a 1am cruise and it still did the same. i have seen the AFM is abit dirty and worse than wear so i might look into replacing it, also did check one spark plug but my cousin said if its sparking and starting then shouldnt be a problem, even with the coil packs (his a hands on mechanic) but this thursday ill be pulling it all apart and having a closer look.....also been looking into buying NGK iridium spark plugs priced at 100. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933013 Share on other sites More sharing options...
boostn0199 Posted July 26, 2011 Share Posted July 26, 2011 Dont waste your money on iridium plugs there rubbish the normal coppwrs are the best. General rule under 12 psi uae ngk bcpr6es and if running over 12 psi go for bcpr7es Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933028 Share on other sites More sharing options...
The Dan Posted July 26, 2011 Share Posted July 26, 2011 Dont waste your money on iridium plugs there rubbish False. There is nothing wrong with Iridium plugs....or Platinum plugs for that matter. They serve their intended purpose. If you want to make 200% more power than Nissan intended, then maybe you have to revisit their design or if you want your 20 year old ignition system bandaid fixed, then sure, go coppers. Iridiums actually have a finer tip, allowing them to fire a much more precise and direct spark at higher intensity. This gives better combustion and due to the iridium tip, they last a lot longer. If he is running a standard car then he doesn't need anything more Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933064 Share on other sites More sharing options...
Rolls Posted July 26, 2011 Share Posted July 26, 2011 False. There is nothing wrong with Iridium plugs....or Platinum plugs for that matter. They serve their intended purpose I think he point was more they aren't worth the money on a modified skyline, imo you are more likely to ruin a plug from fouling it and can buy something like 10+ sets of coppers for the price of an iridium. If the car is running sweet and doesn't need really small gaps and is tuned properly then the extra kms you can get out of iridiums probably gives them some pros though. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933191 Share on other sites More sharing options...
chris pohlman Posted July 26, 2011 Author Share Posted July 26, 2011 yeah well i need to find good products that will give me more than say 12months + not something i will have to fix in 2months. Been driving the car steady, just want to fix this pinging noise at 4500rpm. I have seen a few vids on youtube but doesnt specify what the problem was.... i have splitfire coils but on forums says they dont break..... thats whats in my mind..... $500+ for a new pair, just dont want to start thinking its them in a way........been doing some homework on parts, prices etc.....but rather work from the simplest job to the most expensive. any feedback is greatly appreciated. and anything that has worked for you guys. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933665 Share on other sites More sharing options...
Rolls Posted July 26, 2011 Share Posted July 26, 2011 any feedback is greatly appreciated. and anything that has worked for you guys. read all our posts again? we told you what it almost certainly is.... Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933671 Share on other sites More sharing options...
chris pohlman Posted July 26, 2011 Author Share Posted July 26, 2011 read all our posts again? we told you what it almost certainly is.... i have and i also have found this : R5671A - 8 for my sparkplugs........has anyone used these ones before? Someone had the same problem and recommended them so ill give them a try. Link to comment https://www.sau.com.au/forums/topic/371986-pinging-at-4500-5000rpm/#findComment-5933812 Share on other sites More sharing options...
