sparkplugs won't cause detonation, they can but it is highly unlikely in your situation, it almost certainly CAS base timing is advanced, you are not running 98 octane fuel, or it is a fuel issue and is leaning out.
Get it on a dyno and diagnose the issue, don't keep driving it or you WILL destroy the motor.
was hoping it was the spark plugs in my mind but have a feeling its not. plus when its idling and about to move forward in 1st.... i can hear a belt squeek in a way, been testing it while holding the brake and letting the clutch out i can hear it more......... its never done it before til this pinging noise.....
this car is my daily car, be hard for me to get around.......... imo ....its really annoying :)
+1 have a look at the CAS position , see if someones been messing with it.
having to replace the motor will be even more annoying, do not rev it past 4k and no boost until this is solved, I don't think you realise how serious this is. 10 seconds on full boost with sustained detonation is enough to melt ring lands.
yeah! what he said!!:spank:
Exaclty, it'll be your base timing is too advanced or you have a lean out due to stuffed fuel pump, blocked injectors, broken fuel reg or blocked fuel filter.
Stop wasting time with all the other shit and get it to a proper workshop so they can stick a wideband in the exhaust and a timing light on then diagnose it as either timing or fuel.
Edited by Rolls
Would make more sense as it is extremely common for an annoying misfire at peak torque with stock tune skylines.
Pinging sounds like marbles being shaken around in a tin can, misfire sounds like the rev limiter, pop pop pop
Edited by Rolls
no need for a timing belt, timing light gave me a good reading
Just checking - you realise those two things are unrelated, right? I can't tell from your post.
The cam timing can be off and the spark timing can be fine, and the cam belt can be well past its reliable life, and the spark timing can be fine.
it was making that noise heaps when hitting around 4000rpm... and also the pinging noise was just the intercooler pipe hitting the fan. ive replaced with a shorter bracket which pulls it away from the fan and sits nice and close to the timing cover.
i have fixed both problems but im in the proccess of getting a dyno and buying a timing kit, water pump cam belts. i am doing my best here in researching and learning more about the car.
might help to get your terminology right next time, would have give a completely different answer if you said misfiring and not pinging. Completely different things, detonation destroys motors, misfire is just annoying.
Elite/Rolls - holding all other things the same, wouldn't hot plugs slightly increase the tendency to ping?
I'm pretty sure a 5 is the hottest plug you can get in that size/thread/depth whatever. The factory listing is a 5. Like Rolls said, most unlikely.
Not impossible though. Usually dieseling is caused by lack of ignition timing or very lean mixtures
hmm well i had two sets of problems with the car... noises coming from here and there. The hitting noises were the fan hitting the intercooler pipe making the *tinging* noises .... thats fixed now..... and 4 out of 6 spark plugs were just absolutely f**ked..... i did buy NGK plugs.... good buy, fixed the misfire. currently driving the car at 2500 - 3000rpm. Everything seems to be fine ATM, but you guys have commented on the timing and cam belts, so i will be replacing them when i can.... i have seen the belts and they have seen better days.
    • There's a thread over on PF.com where this has already been beaten to death. I make this point only because the report that you're referring to is already out of date. They have walked back some of the silliness, including the need to apply for (and risk losing the application fee, if not granted) a permit to work on your own car on your own land. But there is still a lot of silliness left remaining. Victoria is a f**king shithole. Has been since way before we started calling it Brackistan. f**king nimby woke Stalinist nightmare of a place.
    • I’ll go last point, For me it’s, can I do better relying on the expertise of u experts in the field but my point was, is there a way and a will to sticky important tried/true/tested facts that come out of a question relating to each area of improvement. I mean like not losing valuable info when u end up relying on google without success. Some times. I just see so much knowledge being passed but unless u are a guru or lucky, the diamonds end up hidden in our forum sorry guys I’ll leave it at that respect
    • Oh, and despite all the links, there's nothing sponsored here. Paid in full by me.
    • What the actual f**k is this about?  https://www.carexpert.com.au/car-news/this-australian-city-wants-to-charge-people-to-work-on-their-cars A $400+ permit, every 3 months, to work on your own car?  Tell him he's dreaming.
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
