Well puling the loom from the coils made it run a bit rougher on each one, so that rules the out. Unplugging the afm made the car stall, so it must be working to some degree.
How big an effect will an leak in cooler piping have at idle?
  • Replies 47
Got this same problem I've been battling for a couple of weeks.
Changed pump Changed plugs gapped to .8 . Checked piping. Problem went away basically after the Pump Then one day the misfire returned worse than ever was almost constant I changed the fuel filter and had a mild improvement
. Pulled the pump out and the sock was so jammed with dirt it wasn't pulling through. Cleaned it out and all good again . Has started to come back again after a week. Anyway i reckon pull your pump out as the sick is probably full of shit
My car did the same thing the day after i got it (blew the intercooler pipe off) Was told it was a realy small hole but F#*K me, it ran like it was on 3 cylinders and blew alot of black smoke. Even if you can't find any obviouse leaks in the intercooler pipeing just have a realy close and good leak. Apart from that i would just do what everyone else is suggesting. Hope you get her running 100% soon :)
alot.
my AFM was rooted, but it still stalled when you unplugged it.
edit: are you north or south?
Im down south Dion. my car is currently taking up space in my gfs parents garage in Morphett Vale :P
a mate had similar issues, new spark plugs, tested different AFM and bought new coilpacks and in the end it turned out to be the ignition module...
Cheers Vu, will add that to the list
okies, will do. what did you use to clean up the pump, im guessing there are some solvents/cleaning products to steer clear of in case they react with petrol
hmm wouldnt have thought a small leak would have such a large effect, we'll see!
Hey Carl
I'm putting my money on boost leak bud
Rough idle , hunting, blowing smoke......all symptoms of an intercooler pipe pissing out somewhere
looks like its the next step
If it's IC piping, you owe me a blowie.
Borrow a working AFM from someone to rule that out too and save you the head f**k of buying one if it's not the problem.
fark that is a fairly steep price for IC piping being the cause :P
Yeah if your silicone joiners are a bit old, thats probably the cheapest way to start!
yeop, my thoughts as well... i have done everything that is free so far. time to move on to the cheap fixes :D
finally got some more time to mess about with the car. replaced a bunch of the joiners with fresh look at me blue silicon and new clamps. there were a couple sections that i could not find replacments for (they have a gradual curve in them) so i have not completely ruled out a vacuum leak.
a couple things that i have noticed in the way that it is running are:
  • it runs slightly smoother at idle. however it is still blowing a ton of smoke at idle and makes a nice cloud on gear changes and acceleration in 1st
  • after a bit if driving then coming to a stop it idles at 2k rpm for a little while (up to 1 min) then it drops back down to around 1k rpm and will surge/splutter.
  • when driving at a steady rpm, a change in throttle position makes the car surge/splutter
  • does not blow smoke driving at a steady speed
  • does not want to boost past 8psi (not that i have been trying to, but the slippery clutch means sometimes i dont have much choice in gointg to higher rpm)
does that info help narrow it down for all?
anyone out there have a working green sticker AFM or RB20 igniter pack i can try out this coming weekend? i work in the city and live in the brighton area
ps, thanks for the help so far :cheers:
Igniter pack will be solid gold bro!
Will clean out my aac this weekend, can hopefully sort an afm to test as well.
Faililng those telling me what the problem is it leaves a vacuum leak that is still there, a borked CAS. Or something more sinister
You my friend are in luck......i have a spare igniter pack and creank angle sensor you can try, but i'm not sure how well the sensor will work as it hit the ground when i pulled it of my spare motor. If you want i can drop them off on my way home from tafe tomorrow arvo (finish at 4:50) so just txt or PM me the addy.
You my friend are in luck......i have a spare igniter pack and crank angle sensor you can try, but i'm not sure how well the sensor will work as it hit the ground when i pulled it of my spare motor. If you want i can drop them off on my way home from tafe tomorrow arvo (finish at 4:50) so just txt or PM me the addy.
Forgot to leave my number......0433 522 234
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
