Any take on why we cant get leds installed in our original rear light housing Ive seen plenty of different kinds on the net but they are all japanese or chinese they seem to get it right but they cost a fair bit like $800aud because your importing it and also buying the hole complete oem housing and lights. Dan666 apparently said his working on it like 1 year ago and said they had abit of problems with the leds not shining through the r32 lens. But again how do people in asia get it done. Looks Totally original when the lights are not on but once on they look mad! I know Dan can do the r34 lights, I kept messaging him every 3 months untill i gave up.
Im shocked no one in australia can fit them in using your original housing after all we have had these cars in australia for around 20 years. I wish i was electrical minded i would of figured it out by now by communicating with someone overseas and figuring out the procedure
Still the same problem, the R32 lens is refracting the LEDs too much and it just doesn't look right. I'd have to get a new board redesigned to suit the R32's which is not likely at the moment due to current commitments. I'm not even doing the R34's anymore due to a supply issue with the components.
Thats fair enough, its just strange your the only one in australia tackling this problem.
i just bought the whole assembly from yahoo auctions, removed my factory assembly and then put the factory covers onto the new led lights. not sure im keen on the "clear" led's anymore and thinking of going to red led's :/
Yes the clear look shit i have the red ones.. Can you tell me if they fit on your car exactly like the oem, No gaps and stuff from the oem covers? Tell me honestly do they fit perfect?
Maybe i just bought defected Leds? if so id have to go buy new ones.
there were pretty damn close to being perfect. i spent the weekend making sure they fitted spot on - a little bit of nouce makes it easy to get the little gap and bolts the holds them correctly to line up. then i just sealed them into the rear panel with a sealant....
but now i think i wanna pull em all apart for the red ones....lol
what do you mean nouce?yeh red is much btter
maybe i didn't spell that right lol... :whistling:
its probably nouse...
umm, like if u have a bit of practical skill/know-how....
I just dont wan to customise the car to fit the aftermarket lights, i would customise the lights , do you think this is possible?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
