  • Replies 52
what grade i can get a mobil1 fully synthetic from here at work for free but its only 5w30
Cool, feel free to throw some free oil my way ;)
Mobil 1 5W-30 with SuperSyn has been improved to provide
even more performance reserve, excellent for
turbo-charged engines that require a SAE 30 or GF-4 engine
oil. Mobil 1 5W-30 is specified for use in Holden Special
Vehicles (HSV) V8 engines with the new General Motors allalloy
motors. Mobil 1 5W-30 is the only oil used in initial fill
and recommended by HSV for the Gen III and IV engines.
This specification is noted on the engine oil cap.
It is also specifically recommended for use in, and is initial fill
for Corvette and Cadillac.
i'll help you with your 30det stuff if you give me some free bottles :P
for one it a rb25det hence why im on SAU more than calaisturbo lol
and like i said i need to be very discreet i dont get it given to me i have to pinch it
Edited by luvpsi
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
