  • Replies 52
You have been told wrong.
All Mobil 1 products are a true synthetic PAO/Ester mix (Group 4 or 5)
Most the cheaper synthetics are a group 2 or 3 (Hydrocracked Mineral Oils)
We (United Oil) have PAO/Ester mix United 1 5w50 and Ultimax 10w60, we also have Double Ester 171
Here are the data sheets
Racing 171
United 1 Racing
Ultimax Racing
All these above products have been are being used in full motorsport applications now, I use the Ultimax 10w60 in my SR20 Racecar but have also used the United 1 5w50.
We have a special for the United 1 5w50, $200.00 Including GST for a box of 6 x 5ltr
Let me know if you want some
Ashly
0417 936 001
United Oil Singapore
United Oil Perth
Hi Ash,
I know you work for United Oil, so will be slightly biased, but what if anything is the difference between Mobil 1 Full Synthetic and the United Oil products ?
What would you recommend for my race car ? I tend to use Mobil 1, but have also used FUCHS (when you worked there). I'm willing to swap if there is sufficient reason to ;)
Hi Ash,
I'n not biased, I dont think you can buy a bad oil these days. True they are all different but if you do a fair comparison between different oil brands that are the same spec you wont find much difference in Performance. People tend to get caught up in Brand Marketing hype, but when is the last time you heard of an engine blowing up because the oil failed?
Mobil 1 products are true synthetics, at least group 4 (PAO) and im sure some have Ester mixed in, or are full ester. All Mobil 1 products are, including Gear and Transmission Oils.
As you know Paul I have worked for many oil companies (Express Oil, Shell, Mobil, Fuchs and now United Oil) I have used all their top tier synthetic lubricants and they all performed very well. But you have to know which products are "true" synthetic. I can tell you our United Ultimax 10w60 (PAO/Ester + Moly), United 1 5w50 (PAO/Ester) and 171 Racing 5w40 (Double Ester) are propper synthetic racing oil. The Ultimax and 171 have been designed specifically for motorsport use. Our United 1 Racing is also a racing oil, similar to the Mobil 1 5w50 (Grey Pack)
I have free access to the United Oil products including the expensive 171 Ester, I currently use the Ultimax 10w60 in my 200sx racecar and the United 1 5w50 in my R32 GTR. I have used the United 1 5w50 in the 200sx racecar but because we sell alot of United 1 I decided to switch to the Ultimax 10w60 for stock reasons.
Your race car either the 5w50 or 10w60, what lifters are you using?
ash
hey ash who in perth stocks united oils? im interested in getting some of either united 1 or ultimax. what would you suggest for a streeter?
Not manr autoshops stock it, mostly trade distributors. Filters Elite in Cannington stock most of our products.
I am happy to supply you direct if you want it, specificaly the $200 special
Ash
  • 2 months later...
Bringing up a old thread I used the mobil 1 5w30 however after 1000 kms I'm not happy with it I checked the oil it has broken down already and has a bit or a burnt smell and gone black I know black is a good thing as it has cleaned all the carbon out but it should not have broken down this quick looks like it's united 1 or royal purple this time for a shot
5W30 pinch.gif ,really not best stuff to use ,
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
