^ ^ ^ Lovan being a Serotonin Reuptake Inhibitor helped to hold your Serotonin together
l-Tryptophan is a precursor for the production of Serotonin. Could be that you don't quite manufacture enough Serotonin in that case.
Could be that periodic use of l-Tryptophan will be helpful then. It's product called "S.A.D." available from naturopaths, or chemist/healthfood places that have a naturopath on deck or yours truly.
  • Replies 42
Amusingly enough, the quiz/test they do before they put you on anti-depressants is called SAD - Stress, Anxiety and Depression.
I'll probably grab those melatonin pills you mentioned (I found the link to the store), and see if that helps. If so, wonderful! Then I just have to keep it mild so that my body can learn to do it all itself.
If the Melatonin works, then the +ve knock on effect is that
* there'll be less jetlag on E>W flights or W>E
* your immune system rises to prevent about 20 different types of cancer
Older people tend to produce less Melatonin > sleep less hours > more prone to cancer
But...
* if you need to do a #1 in the middle of the night, it's better NOT to turn the toilet light on ie. do it sitting down.
Turning on the light can stimulate Melatonin production and reduce the capacity to get off to sleep again.
Principle:- Daylight helps to produce Melatonin > Nighttime helps to secrete/utlise Melatonin > Soporific effect
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
