Hi Guys,
As thread title suggests I've got oil in my radiator.... Car is a '97 Stagea (RB25DET) converted to manual last year. Car doesn't miss a beat or run hot. Can take the radiator cap of and when it is running it doesn't blow bubbles or anything but their is defiantly oil from somewhere inside the radiator. Engine has done 155,000. Its not got heaps or anything.
Where do I start and what should i do?
https://www.sau.com.au/forums/topic/372125-oil-in-my-coolant/
Might have a cracked head, its definitely a hard one to diagnose..
Theres also a coolant opperated oil coover on some nissans, not sure if your model has got one..
Anything that mixes coolant and oil could be the problem really...
I wouldn't say its a poorly serviced, radiator was flushed and new coolant went in 9,000k's ago so I doubt its that.
Simon how can I check if its the oil cooler assembly?
Its odd in the fact that oil is in the water but no water in the oil if that makes sense? eg. dipstick is just oil and when i did the oil and filter last week no water was in the oil :/
Have a few photos on my phone will upload soon
here are the photos apologies for the quality, iphone @ night isnt really that great....
The pics make it look alot better than it is.....
While I was out their i stuck my finger in the radiator and if u bend it around and feel the top of the tank its got a light layer of the oily gunk on the inside of it.... :-(
Update:
Today I got the car compression tested and TK tested (checksfor combustion gasses in the coolant).
Compression results were as follows: 1. 155 2. 160 3. 135 4. 145. 5. 160 6. 160.
TK test showed NO sign of combustion gasses in the coolant.
When I first dropped the car off and left they called within15 minutes asking for me to come back as they wanted me to show them what I wasworried about because at the time when they first pulled the cap of their wasno oil or anything around but by the time i walked back a little bit hadbubbled up. Mechanic assumes that the headgasket might be on the way out but it’sin its VERY early stages.
He suggested that I lower the boost (currently at 12psi) becausesometimes It hits fuel cut when you boot it (saying that this is very rare as Ibaby it mostly...) and that I just monitor the temperature and oil and coolantlevels.
Just after a couple more opinions on it, perhaps I shouldjust monitor it and keep my eye out for a wrecked stag and buy the donk....
Rough prices was $1500 for head gasket (metal) replacement aslong as my head is fine or worst case scenario $2500.
Thanks once again guys J
a bit strange you have no bubbling in the radiator and the combustion gas test came up negative.
Have you pressure tested the cooling system. i highly recommend this, its a check i do first when any car comes into work with a possible hg issue.
if you have a substantial pressure drop over a short period of time and theres no coolant running out on the ground you have a pretty good idea its going somewhere its not supposed to, like into the oil or into a cylinder!
pricing for headgasket job sounds fair enough, maybe go ahead and do it anyway if you plan on boosting the car more, that way you have a nice strong metal headgasket plus you rule out that being a problem.
Thanks for your input cam,
Yeah it is interesting it came up negative, but he did say that I've caught it VERY early and still suspects HG
I haven't pressure tested the cooling system no, theirs no milkshake in the oil or under the cap... yet
Yeah id do a metal head gasket but in saying that im running a stock turbo and you dont want to put more than 12psi through one of those with a ceramic wheel so is a metal HG really worth it
its worth fitting if you have a blown headgasket anyway, and if you plan on going bigger turbo down the track.
i suggest going back and asking them to pressure test the cooling system and go from there.
you dont have any power steer or transmission fluid cooling through the automatic radiator do you?? just checking as there might be a hole between the oil and coolant tubes and oils getting in the coolant that way.
its it auto?
commodores blow the auto trans warmer into the radiator quite frequently and it looks like you have a blown hg but its actually trans fluid = negative TK test
if you can, run an external cooler for a few days and see what happens
also, get them to drop some oil down the bores and re-do the comp test
and they should do a leakdown test too, that will tell you more info too
Update:
When I first dropped the car off and left they called within15 minutes asking for me to come back as they wanted me to show them what I wasworried about because at the time when they first pulled the cap of their wasno oil or anything around but by the time i walked back a little bit hadbubbled up. Mechanic assumes that the headgasket might be on the way out but it'sin its VERY early stages.
seriously could swap in a new stagea neo engine for 2500... including fitment. Simon is on the right trach with the heat exchanger too.
Yeah thats it, could put in another Stagea donk fairly cheap... But how do I know the replacement isn't shagged too?
How hard would it be to put a NEO into it seeing as it's a series one stagea whiche have the pre NEO rb25det
Pretty keen to get it happening as I dont like the idea of not being able to rely on my car...
post a pic as a poorly serviced car will get a rusty looking foam build up in the cap area.... its often mis diagnosed as head gasket.
I still think this is the most likely reason. Give the colling system a good flush and perhaps clean the radiator.
Other than some crap in the radiator, are there any signs of a blown hg?
loosing water?
water in oil?
loss of power /compression?
zorst in the water? (already ruled out).
Even if there is....if it is "midly blown" or "early", I would got straight for the chemiweld. Best case it fixes the problem for $10. Worst caase the motor is a bitch to clean for rebuilding....but as said above you would probably just start with a new one.
Hi Duncan,
Thanks for your wisdom :-)
Ill try and get another photo or 2 today and we'll see the difference from the other night.
In regards to other signs of a blown HG it hasn't shown loss of water or oil yet, but i'm assuming this is because I've caught it so early and the amount of oil is very minimal. But it does feel like it is lacking a bit of power but im not sure how much as I very rarely drive the car hard at all. As you can see it is down on compression between holes 3 and 4 perhaps this is where the leak is.....
I dont really want to put chemiweld or an additive like that into it truth be known.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
