just got an R32 GTST shell, have fitted an RB25DET and box,
all the power steer lines/pipes were given to me in a box and im trying to use the rb25 power steer pump which doesnt have hicas.
has anyone done this?
any one have a diagram of the r33 and r32 power steer system so i can see what i have to do.
cheers
by far the easiest thing to do is buy a HICAS lock bar (dirt cheap these days) and remove the solenoids, lines etc.
Then just use rb25 pump and r32 resoviour. I feed from the bottom of the resoviour to the pump inlet, then 1 line from pump to rack, and 1 line returning from pump to resoviour
This is exactly what i was needing help on for my conversion. I dont have any of the lines, I already have all solenoids removed and a lock bar fitted, so i wasnt sure how the pipes should be run either.
Because the hicas is gone, can i just run the pump to the steering rack then the steering rack to the resovior, then the resovior back to the pump?
I was thinking about getting some banjo bolts with the barb fittings and just pushing on the hose lines. what do you reckon?
Im heading to pirtek in a few minutes.
Once i measure up how i'll run the lines and what fittings etc ill post up how i did it.
Will be from reservoir to pump - pump to bottom fitting on rack (high pressure pipe or crimped connectiins) - rack to power steering cooler loop near radiator (low pressure hose and clamps) - from cooler to reservoir
Yeh let us know becasue I will be very interested to see how you go with it. I dont have the cooler section for mine so im not sure whether it would be needed or not seeings the Hicas is all gone :blink:
  • 3 years later...
Sorry for Necro but...
I'm putting a NEO rb25det in an R32 and also having issues with powersteering pump alignment and HICAS removal. I have the RB20 pump, an RB26 pump and neither seem to provide any joy. Next step is to source an RB25 setup, will any RB25 Powersteering pump work or does it have to be off a NEO?
You will not be able to make it work with the old pumps on the new motor. The pulleys are different. OK, you may be able to make it work if you can find/make/adapt/space a suitable pulley.
Plus, one of the benefits of doing Neo into R32 is to get yourself some engine ancillaries, like the PS pump, that are 10 years younger than the old RB20 stuff!
So, the answer is to get an R34 pump and be done with it. After that, all that is required is to get the hoses from an R34 and attach them to the engine bay pipework for the R32 rack. Some Pirtek/Enzed assistance is required. Piss of the plumbing to the HICAS gear and throw it all in the skip.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
