  • Replies 158
Wow. Which comp? Which fed? What did you end up successfully squatting at that comp? Or did you open on 300 and bomb out?
275kg
https://www.google.com.au/url?sa=t&source=web&cd=9&ved=0CE4QtwIwCA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DN8JfBrZnIVo&ei=JrRXUZWzCML0kQX-0IDACw&usg=AFQjCNFKcRqlhkCONVRxjEmLr1DD-4feGQ
Not to bad.. I couldnt walk properly the week before the comp and have been at physio twice a week for my busted shoulder and hip.
Wanted to do nats equipped but its too painful training so im cutting weight atm.
275kg
great lifting mate! hope you see some progress with your injuries
Christian, you know youre going to have to come to Melbourne for Nats.
The following week after NSW States Zoran pulled 292.5kg and took your deadlift record, then a week later Jeremy totalled 735kg and took your total record, you still have the squat record. I hear Ricky Goodyear may be doing QLD States in the 125's and going over 870kg with something like 330/210/330.
It will be good to catch up again, looking strong
I wanted to open squat at 275 300 315 . However like I said injuries. I need to seee whats happening with my shoulder and hip. I injured my shoulder at trents comp when you were here and it hasnt healed since.
Im not suposed to be lifting at all says surgeon. So im not sre about nats.
Wow, that was a long time ago, I didnt realise you got hurt
Wayne at ABC tells me you guys got a heap of Ivankos, nice
I tore my supraspinatus got bursitis frayed my bicep tendon and have a slap tear in my left shoulder.
9 cortisone shots later.. still no good. Explains shitty bench.
Yeah have a bit of gear here, basically everything.
Pretty sure the only way slap lesions can be fixed is through surgery but I could be wrong. You would think after a couple of cortisone injections they'd realise it isn't helping though...
Either way, I hope it all works out for you.
They did 3 shots under ultra sound over 3 sessions
sub acromial space
Bicep tendon sheath
Ac joint
Its a lvl 1 slap tear.
Its alot better then it was but I still get numb hand and pain. Doing bench press my left arm loses all force when nerve gets pinchued from entrapment and it gives out.
Surgeon said I wouldn't lift again. I did 3 reps of 180 with a sling shot and 4 x 140 week before that comp.
I cant see myself having a prosperous bench only career though. So I need to heal this hip and make up for it in squats or deads.
been lifting for a couple of months now, can do 130x5 (current bodyweight) and 110x10 ATG (the advantage I guess of being a fatass + strong legs). Going to concentrate on getting DL and bench up to the same numbers now!
I always back the weight off if something ie back does not feel right.
I find the big compound movements a quite enjoyable part of any workout, feels like i am getting more 'bang for buck' than doing isolation excercises.
Any skateboard squatters ITT? :D
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
