Nissan Varietta
SR20DET Turbocharged
6spd Manual
Performance:
Greddy Air intake kit
Greddy Intercooler
HKS Airfilter w/ Z32 Airflowmeter
Tomei Front Pipe
Tomei Dump Pipe
Sard 550cc Injectors
Fujitsubo Exhaust System w/ Custom tip
Extractors
Hi-Flow cat
Stainless Steel Manifold (Returned to stock)
Cooling:
Greddy Fuel Regulator Pressure
Sard Racing Radiator
Handling/Brakes:
R33 Rotors/Brakes/Calipers
Silkroad Spec RM/A8 Coilovers
Exterior:
Full Supermade Instant Gentlemen bodykit (Imported Japan)
Origin Led Tailights
Wheels:
SSR Viscontis
F:19X8.5 R: 19X9.5
System/Exterior:
ECLIPSE 7"inch WIDESCREEN TV/DVD/NAV
ECLIPSE 6CD Stacker
Misc:
Xenon HID Lights 10k
Greddy Fuel Reg Gauge
Momo Gearknob
Momo Racing Steering Wheels
Full Leather Seats w/ full heating. Luxury edition.
Leather interior and heated seats.
Price: $29,990
Alot more on the vehicle. Open to nearest offers.
Feel free to call for more information
0433 759 695
Leave an sms/call.
Great summer car.
HENDRICKS_13.jpgHENDRICKS_09.jpgHENDRICKS_07.jpgHENDRICKS_05.jpgHENDRICKS_01.jpgHENDRICKS_02.jpg
Edited by senyum
oh man this thing is amazing!
does it have diff rims on it now? because they look like autocouture's.....?
game is a little bit rich for me at the moment, but i'll be watching for the price drop!
thanks mate. nah there ssr visconti wheel
Mate seeing how these only came non-turbo, what motor is it running? Turbo motor? Or standard n/a with a turbo slapped on.
Also if a turbo motor, from which series (s13,s14 or s15)
Thanks
Seen this in the flesh at my panel beater when it was getting the kit sprayed and fitted. Looks a lot better in real life mate, and then knowing that it's turbo makes it all the sweeter
Good luck with the sale
thanks stawka! have you sold ur car yet?
haha na man, worse! I lost it on the way to work many moons ago and stacked it into a pole. Was raining and there was diesel on the road coz it happened outside a truck rental place. (gotta update my sig but cbf)
And yes, even the police said it lol. Your car looks mint man!
  • 1 month later...
  • 3 weeks later...
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
