Hi All,
I currently bought an R33 V spec Le mans edition and having most of the parts required . My specs are as follow;
Haltech Platinum ECU
JUN oil pump
Tomei Piston
N1 Crank
HKS GT2540 (Twin)
Twin Plate
HKS 1000cc injector
etc.
Currently i am having a issue of choosing con rods whether H or I and what bearing should i use.
I am now looking at Nitto H beam con rod or Eagle rod and i should be expecting ard 750 HP or more after tuned.
Any advise whether should i use H or I beam rod and what bearing should i use.
Your advise is crucial of whether should i get a Normal Eagle Con rod or nitto I beam rod.
Also, what recommendation will you give for improvement?
Any 1 has the same turbo setup? mind sharing the result in quarter miles and whether twin plate is good enough?
Thanks
https://www.sau.com.au/forums/topic/372166-advise-needed-con-rod/
As for rods Eagles outta the US are cheap. As are Tomei rods as well at the moment.
With regards to the H vs I debate, read this thread and decide yourself (or simply talk to your engine builder?): http://www.skylinesaustralia.com/forums/topic/173552-h-beam-vs-i-beam-conrods/page__hl__beam
Apart from that I think you'll be hard pressed to make 750hp on HKS 2540s
HKS 2540s are a "mis match". One of the worse turbos you can purchase really. They will make a similar amount of power to a 2530 (~400rwkw), but with more lag, and they tend to be quite surge prone. Kinda like a GT-RS (new generation), especially on a 2.6ltr.
Hi All,
JUN oil pump
Tomei Piston
N1 Crank
HKS GT2540 (Twin)
Twin Plate
HKS 1000cc injector
etc.
Thanks
As for your rods get the ones with the larger rod bolts visit the Manleyperformance.com web site and download catalog it has info on what rods might suit you needs
Same, weve used Spool in everything pretty well. Not one issue with them, upto 800bhp.
Most of everything these days is made in China, even alot of the big name stuff you wouldnt think is. But the quality is getting better and better now, especially the companies who have their own QA over there keeping things in check.
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
