Hi guys, has anyone had this problem before? My 260rs is stock as a rock at the moment, it has a missfire only on cyl 1.
Compression is perfect
I have replaced coils with new splitfire items
Tried known working sensors off a mates car, afm, tps, aac,cas
Changed injectors
Changed spark plugs
Changed ecu's r33 gtr & pfc could make it better with power fc but not right
Have checked everything for leaks or loose clamps ect
Could it be something with the harness? Or something simple?
An
https://www.sau.com.au/forums/topic/372191-rb26-missfiring-cyl-1-constantly/
Would a stuffed throttle body seal cause it to do this?
Unlikely - if you have fuel and spark on that cylinder than it's time to check compression. Have you even pulled the spark plug out to see what it looks like? Might just be easier to take it someone that knows what they are doing. It may take my an hour to write out all the things you need to check but if I had the car and 10min I would be able to find the cause.
The car has been at autosport in sydney for 5 weeks and they couldn't fix it,
compression is even across the board
it's running a lil lean if anything as the plugs are white
drive fine when on boost!
will be pressure testing the inlet tomorrow to try find a leak but have already been over every hose and clamp associated with it,
the only thing on the inlet that wasn't replaced with new items is the throttle shaft seals! it needs to be getting the extra air from somewhere!
will post how i go tomorrow
mate if u can fix it in 10 mins I'll give u a $100 dollars, Should be a easy $100 for u :)
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
