ok so i have searched and read through about 40 of the 75 odd pages in the skyline wheel fitment thread...
found a couple similar results...
after pics of fitment with stock guards (obviously flared/lipped) on a 32 GTST with
17x9.5 +12
fitted with 215, 225 or 235 40 or 35 series tyres. Rims are already on the way so just sussing out sizes. fronts running -3.5 camber rear camber is -0.75, would rather do guard work than change alignment settings ;)
https://www.sau.com.au/forums/topic/372204-r32-gtst-fitment-pics-please/
Here's mine with 17x9 +5 and a 215/45R17 on the front. I haven't had my camber measured but at a guess I'd say I'm running about -3deg. Your rim would stick in 1mm than mine but not sure about what tyre you'd wanna run.
As for the rear you'll need a small flare I reckon.
Hope this helps a bit.
thanks bud keep em coming...
currently running 17x9.5 +12 on the rear with a 215/45 federal and pokes a bit, front are 17x9 +15 with 225/45 and sit flush .. just unsure on 18s and tyre profile...
was wanting to run lower profile but not too sure how this is gonna stretch.
18x9.5 +15 all round
stock flared guards
235/40/18 feddy 595ss
low.
now camber arms or anything.
mannn thanks so much this is exactly the specs i was looking at and ive been wondering for ages if it will work with no camber arms, you rule!
i did my guards.
they were rough as i had 1 day to do them before hitting the track, i got them much better after when i had time.
use tape to tape up how you like the flare, then use a hammer and smash the shit out your guards.
i started hitting soft but realised i needed to hit HARD..
I'm just about to purchase some rota Grids in 18x10+22 and 17x9+15
I know these would need some guard work and some neg camber, but any idea how much. Shouldnt be heaps if i have some stretch on the tyres, rears especially?
This is on stock 32 gtst guards btw
I ran 18 by 9 +22 and with 235's it rubbed even with lipped guards and max camber on the rear, fronts were just ok with camber and caster arms.
Imo with stock guards and mild lipping a 9 +22 is as low an offset as you should go.
There is still alot of clearance inside on the rear so a 9.5 or 10 should fit easy with correct offset.
Btw running anything smaller then a 235 on a 9.5 is stupid and dangerous, if you cant fit the wheels properly dont buy em.
Unless you want to roll and pull the guards a little then a 9 +25 ish is good on the front, the rear can have wider, say a 10 but the offset has to be right.
There is also issues with inner clearance on the front, especially with 18's as they only just cleared the sideskirts and front bar.
IMO 17's are a good compromise between looks and practicality. 18's look better but you can fit 17's alot easier, I have just bought some 17 by 9 +22's and even with 245's they didnt really rub, nothing compared to the18's which rubbed on every corner on the back.
Plus 17's are alot cheaper for tyres :thumbsup:
  • 3 weeks later...
so the rears fit.... 235/40/18 with 18x9.5 +12
unfortunately I didnt think about the effect having a 33 LCA up front would have on the track so they sit about 12-20mm from the guards... going to try massage guards some more, failing that go a weaker offset.. this is a last option lol.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
