Did back to back dyno testing at Boostworx. Eflex made less power then normal 98. The liberty e85 made 15-20kw more. Eflex isn't e85 its e70-e85 as it says on the pump.
While I dont doubt your figures this is totally the opposite of the testing I have carried out for our own vehicles.
However I have never tested 'Liberty' E85 only the United CSR Sarina manufactured blend, I think you may be getting confused with United. If there is a Liberty selling here let me know and I will test it.
E-Flex is a much maligned fuel. As stated on the brochure on the Caltex servo counter this fuel WILL contain as little as E70 in some circumstances, and yes it has when I test it (71% concentration is the lowest measured directly). This gives the fuel an effective tuning RON (my calcs here, not measuring on an octane machine) of around 110 - 112 RON. It is also highly oxygenated which means that it is capable of delivering good combustion energy - significantly higher than that of E85. I do not know why Boostworx have found it makes less power than 98 octane fuel as on a typical 200rwkw turbocharged engine (on a Mainline dyno) we can normally extract in the order of 10% - 14% additional power and torque swapping from 98 to E-Flex. The tuning technique required does however require some thinking outside of the square with some engines.
Yes, my family hack is a Flex-Fuel setup EVO X, and yes it runs on either 98, or more preferably (as it makes a ton more power and costs $40 a week to run) E-Flex :)
CSR Sarina E85 is a little more pure for the racers measuring at around 88% Ethanol in most cases and can make a tad more power than E-Flex (not a great deal in it). We run the United CSR blend in - all - our Willall Racing track and drag cars, but maybe we are missing something? :pirate:
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5936774
Yup, I meant United not liberty on Tapleys Hill Rd >_<
Not to sure whay exactly it made less power then 98, wasn't by much though 230rwkw vs 226rwkw. Could have been a bad batch of fuel or it could have been down to tuning technique.
But as I said, and you stated above. The United E85 will make more power then eflex as its a more pure blend. Considering the United E85 is as cheap as eflex I know what i'll be buying all day every day.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937061
Cheers guys.
Considering runnoing the evo on it.
A few blokes from other states have been doing it for awhile.
Have seen back to back dyno results and have been impressed...
As far as 'stuffing things up' i havent heard of much. what are the risks?
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937191
Here, here, good to see your still a champion for the good stuff Mr Donnon.
I say go for it, Eflex is more than capable even at 70%.
I use the United E85, but have no problems at all throwing in Eflex,
United's wins on my seat of the paints dyno.
Recently tuned a S15 SR to 1.85bar on E85 running a disco with all the bolt on's, got a good compromise mapping both fuels, hasnt had it's power measured yet, but far out it fly's, high 200's at a guess.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937549
.82 rear or .64? I've got the .64 making 240rwkw at 20psi dropping off to 16psi (small wastegate). If you have .82 is there much lag? would be keen to see power graphs as thinking of changing rear housings on mine.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937604
I'm amazed at the attitude towards E70 vs E85............I think peeps are forgetting that the fuel alone won't give you the kind of power you're looking for.
In fact, 98 pump fuel will burn much better (combust) than the higher octane Ethanol.........the stuff just doesn't burn!!!
What the Ethanol allows you to do is turn up the boost and and throw more ignition timing at it, hence where the additional power comes from................the stuff doesn't know the meaning of the word Detonation!!!
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5938071
people still hate on e85 haha, i have been running e85 for 3 years thanks to adrian, never had a issue pushing awesome power! it really is power for nothing compared to what some people spend chasing small gains, as well as safer. as for blends tryed nearly all varietys and never had issues.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5938162
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
