.82 rear or .64? I've got the .64 making 240rwkw at 20psi dropping off to 16psi (small wastegate). If you have .82 is there much lag? would be keen to see power graphs as thinking of changing rear housings on mine.
Hey Ryan, it's a mate's car, looked like a .6 rear to me. It's coming back for a tickle once we fit a better dump and 19 psi actuator, ill let you know how we go.
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5938433
E-flex is available at Caltex on O'connel st, North Adelaide. I grabbed a few L into my jerry can for some testing. Using this method I calculated it to be ~72% ethanol, or ~E72.. My crude test lines roughly up with Caltex's claims of being E70 atm.
Tempted to test it in my car, but since my T518z is maxed out, I don't think I'll be netting a power increase of any more than 5%. Well, only one way to find out!
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5938555
Its interesting reading peoples opionions on it.
Some real haters to real lovers.
No one is imbetween, u love it or hate it.
Still considering throwing some large injectors and bigger fuel pump in the evo and giving it a crack.
Needing to find places close to me that sells the stuff tho.
Has anyone heard if it will become more and more comman, soon??
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5938971
one of my mates was saying that 91 fuel is meant to be no longer going to be sold at servo's in aus. the cut of date is meant to be some time this year. tho after a quick google con't find anything on it. it's supposidly meant to be replace by ethonal based fuels.
this is only what I have heard so it could be BS but some of the new commys are coming out ethol ready or something i'm really not sure.
anyone else heard similar?
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5939229
I use eflex in our car and although the dyno said the car made less the black top said it makes quite a bit more. The car has gone from running consistant 125mph quarter mile passes to consistant 135+mph passes with just the fuel change. We didnt bother putting more boost into it as it wouldnt stay in the dyno so we just left it where it was :D My seat of the pants dyno also tells me that the car is much nicer to drive at any point in the RPM range
I would recomend it to everyone thats for sure.
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5939241
heard a runour from a mate that 91 octane will no longer be sold at pertol stations as of some time this year? anyone confirm?
supposidly going to be replaced by ethonal based/blended petrol, but again just wht i have heard.
hopefully this means most petrol stations will start to have e85 or at least e70
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5939245
Real lovers = people who have used the stuff
Real haters = people who have not
That's the way it comes across anyway.
^^ Yer without sounding like a dick or starting arguments, thats what i to have come across.
A concern of mine is that it hasnt been used for say 5 years yet. To get that long term issues etc. As i expect to keep my evo for awhile
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5939303
well i have used it for abit and im very happy with it.
cant push aside the fact it gives engine protection. and when ppl start pumping boost into engines you wouldnt mind the extra safety..
heck look at simon, he has run ~350rwkw on a STOCK bottom end for AGES and that thing has seen a hard life. i put it down to e85!
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5939345
Your not wrong.
I like driving my E-Flex rb20 just as much as driving my 300kw 98 powerd rb26, the rb20 smokes 3rd the whole way down the start-finish straight at lala :D
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5939892
a quick search on the caltex site lists these as selling e flex, with more to come by october. interestingly, GM state that over 50 % of their cars sold in Aus will be ethanol based by 2012 end
http://www.caltex.co...s/BioFuels.aspx
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5940183
correct. Its a Govenrment policy that unleaded 91 will be pahsed out
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5940254
Even 100RON E10 seems to have much better drivability than 98. It was very noticeable in my R33.
Definitely, but United have had supply issues apparently and have dropped it. They're expecting to have it out again soon though.
What is required as a minimum to try eflex? If there's a servo in North Adelaide I might give it a go, but I was of the understanding I'd have to do injectors/fuel pump/tune?
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/2/#findComment-5942888
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
