^ that's exactly what i was going to point out.
its the higher boost that is making more power, and all the E85 is doing is alowing more boost to be run without detonation.
I think my GTR could make near that if it were able to hold 25psi boost, but it seems to peak at 25 then trail off to 20psi
Anyway's, will see what it does on the dyno this weekend
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/3/#findComment-5957269
Are you running standard or aftermarket actuator / wastegate springs? Judging by Donnans HPI article, youd see some good results with a stiffer spring!
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/3/#findComment-5957406
I've got 14psi actuators from memory? i remember when i had them fitted to the std motor the tuner had to just run wastegate tension because when they were plumbed in boost would hit 18psi.
i've got an Turbosmart E-Boost Street, so it should be able to control boost well enough. might just need some fiddling with the settings to control the wastegates better?
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/3/#findComment-5958590
shouldn't i just be able to have the wastegates tightened to hold more boost?
i think they're adjustable, they have a threaded rod which looks like you can tighten of loosen to adjust when the wastegate cracks open.
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/3/#findComment-5958653
yeh go speak to jason at mtq.
my external gate hold 20psi flat, put 25psi through it and it bleeds back to 20psi, fitting a stiffer spring will mean boost holds and it bosst will come on earlier too :)
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/3/#findComment-5958676
  • 8 months later...
