haha yeah i was a little worried about that, he said the car was slipping off the dyno but he had no one to help keep it down.
Interesting. What tyres are you using? Shouldn't be slipping when its only making 270 odd rwkw.
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6368708
Dunlop 18s, but i did recently put stock suspension in and the shocks arent in the best condition. He assured me it is nothing to do with the tune as the afr and boost graphs are fine. im putting the coilovers back in after this weekend then ill get a power run and see how it goes, or ill be at the dyno day if that is still happening, interested to see what i make on a mainline.
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6368809
200... I hope there was some sarcasim in that, Im sure the figure wont drop 70kw. Either way im happy with the increase in power and how the car runs from changing to E85. I know how good Willall have proven to be but at the moment i am happy to take my car to Boost Worx.
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6369675
I wasn't be sarcastic, but I won't say anymore
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6369969
Jet's F6 went from about 420rwkw on a DD to around 360 on a mainline
I went from 270rwkw on DD to 250rwkw on a mainline. There is definately a discrepancy - that said, do the ramp rates even correlate between the two brands?
-D
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6370082
Just got my car back from BoostWorx, Made a 30kw and 50nm gain.
When does it get full boost in 4th? I have an AX53B70, full boost is at 3400rpm in 4th (no brake tricks, not up hill). Yours looks a touch higher from the dyno - but it's the road that matters.
When mine came off the dyno it took until ~3800rpm in the road to hit 15psi. I richened mine up a touch (about 5%) in the mid-range on the road and it helped ALOT with 3000-4000rpm. (98 octane).
Edited by simpletool
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6370984
hey guys first things first 30rwkw is on the money for a e85 changeover congrats on doing it bud its great fuel and works wonders for $ to rwkw
but no real reason why a car is allover the place on a dyno, the setting up and strapping down part is just as important as the tune imho not just for safety but for a honest as possiable result on ur progress.
now the dyno debate is a killer dont try to work it out it just is what it is .....farked lol but i will say this there are many workshops in s.a that know what there doing and then others that dont have a bloody clue. this is where willall get big props they are very particular on the strapping down process and there mainline dyno ..............ill say this very honestly ..............seems to be bang on the money for rwkw vs mph not everyone likes to used the same workshop as others and so on but r33 a mate has was tuned on e85 at willall eflex of all crap and came out with 240rwkw on 98 then a direct 270rwkw after the e85 tune, so ur seeing what u should be
yes pete the willall dyno makes the men stand up lol but had a fair idea the first d/d was down hill,
just for a larf we seem a bf f6 typhoon do 275 on one dyno then coupla hrs later 360rwkw on another .....................boggles the mind
but just remember we have a strip now so no guess work, mph is a true reflection for power.................get to the strip lads
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/5/#findComment-6371794
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
