martin has that killer ( i think ) option on his evo with a flick of the cruise button on comes the e85 tune thats gold i think 30psi is huge fairly sure martys wrx was doing plus 300kw on e85 at 21-22psi
again wicked work marty
Edited by JETURBO
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-6446925
My mate just bought a evo6 with only an exhaust and fuel pump, got steve knight to play around with it and made 250awkw on pulp. Steve did tune it on 30psi though haha, seems pretty high to me but i know nothing about evos.
Took my car to Steves just after I got it, asked him to check it out on the dyno and make sure its running ok
next day its running 25psi gone from 170kw to 220kw with just a cat back.. :laugh: although it wasn't the safest tune around, 30psi on 98 stock turbo is huge
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-6447224
Evo6 wont sustain 30psi on a stock turbo. The turbo is nowhere near big enough to get it done. Take that as read ;)
30psi can be spiked through it low in the rpm range though, bend all the rods and get them to kick out the side of the block.
30psi is massive boost for any production petrol engine....good luck with it! :)
(Thanks Jet)
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-6447426
I can pretty much guarantee that there is no way in the world that turbo was running anywhere near 30psi. Anything over 25psi on a stock Evo turbo is pointless as you're only creating heat/stress for very little (if none whatsoever) gains.
My stock 2.0l engine/turbo Evo 6 makes a reliable 270awkw on 24.5psi with E-flex tuned by SKR. Thus far, it has been good enough for a string of 1:15's around Mallala and 1:04/1.05's around Wakefield Park. There's no chance the car would be making that much power and producing those lap times on 98. E-85 is my best power mod to date and if you haven't already done it, do it!
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-6464466
  • 8 months later...
  • 2 months later...
Any more updates on places that sell it here in Adelaide ?
Any more places ?
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-6893567
Pooraka have ran out twice on me before and once I had to wait half an hour for the tanker to move so that I could fill up. I keep 2 jerrys full at home now just in case
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-6894302
  • 8 months later...
  • 5 weeks later...
Hi guys, im fitting new injectors and fuel pump soon to change over to E85, am i able to refill the tank with E85 and drive it to the tuner without making any ecu changes? or would it be better to run the new pump and injectors on 98 to get it to the tuner and let them change the fuel?
https://www.sau.com.au/forums/topic/372229-e85-fuel/page/8/#findComment-7246250
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
