Hey all, Ive got a 32gtst with a standard rb20 in it, and what i thought was the standard box, but have been told this is not an RB20 box.
Just trying to work out what it is, and if it's ok to continue using it in my car/or what I should sell it as.
Notice the gearbox is mounted using only 2 holes, and also the shifter sits slightly forward:
Any help would be great,
Cheers - Sam
Edited by Sammy B
https://www.sau.com.au/forums/topic/372236-can-someone-identify-this-gearbox/
That looks like a CA/SR box, is the yoke sticking out, at the rear of the box? that crossmember is bolted in backwards aswell by the looks of it
CA/SR has the starter motor bolts facing the other way and no the crossmember is around the right way. The high side is the exhaust/passenger side
That gearstick position is what happens when you put RB20 manual into RB20 auto body. The holes are in different locations. Not a problem, except it causes the rubber boot to push the gear stick backwards a little when in odd numbered gears.
My 32 was auto before its conversion and i don't have this problem
Have you had your vehichle fasted? You can see if it came from factory with an auto.
No, I have not had it fasted. That may help work out if it was perviously auto, but I still have no solid idea what that gearbox is from. Also if it is a ca/sr box is there any reason why I shouldnt continue using it?
Any thing i should check/pictures i could take to help determine what it is?
Well, so was mine, and I do (although it's not a problem). Must be different by year or something.
could be a r31/vl gearbox . as for the hole position , i vaguely remember a friend of a friend of a friend of a mate telling me that they spaced the front crossmember/engine mount points (or something like that) slightly different in the auto (something about the bellhousing on the auto bla bla) .
Disclaimer: don't take this information as gospel , i didn't personally discover this nor have any intrest at the time of what the guy was talking about so information is fairly sketchy
I've had both an RB20DET box and the current RB25DE box in there and the stick position is dead the same. Apart from ratios, those two boxes are identical anyway. Can't comment on stick position of RB30E box, as I have had one within 20' of my car.
You have the wrong mount on the back as well. There is about 5 different brackets for nissan. they are a,b,c,d,e
I think you need the ( a ) bracket for that conversion and it will line up with the bolt holes for the original mount
i still reakon, it is a short type fs5w71 bolted to an RB20 bell housing.
same crap as they are talkign about below (but obviously dif. combination of boxes, most of the bell housings are the same length, but the main shafts vary in length after the sandwich plate, and the rear of the box can be longer & shorter depending on what it is or in, sometimes you have to change the input shaft or the front bearing plate that bolts to tht bell housing. you get what i am saying
http://club-s12.org/v3/index.php?topic=12333.0
Just checked the plate on the firewall, appears it did used to be auto (reads RE4R01a)
If its working fine just leave it there
Working fine, but the clutch is on it's way out, so the box has gotta come out either way (just a matter of whether it goes back in or not)
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
