Im hoping the turbo does turn out to be a good thing and that ive made the right choice and im all bout midrange and the smile it gives me with my car :nyaanyaa: haha
ive heard joeyjoe fella using 550cc injectors with E85 making 320 or so rwkw my car is purely for thrills so fuel economy doesnt come into the picture for me.
Im a plumber by trade( i do have a good mechanical aptitude tho) :wacko: but im wondering if making extra power by changing fuel as apposed to mechanically I.E( more boost bigger cams etc) is it making my engine more reliable???? If that makes sense? haha
Hamish is doing this with a Pro S not a KAI
The KAI has proved disapointing in comparison. I pulled 243rwkw on monday with my new front cover. Mind you I havent pushed the tune yet (there are reasons behind this) but its a very slight gain over the standard front cover and its got a bit nicer curve
Just so you know, you wont be seeing 320rwkw on E85, the KAI is fairly more responsive at least by the looks of it, More like GT-RS sort of driveability
So he prob will get hes target of 270 on e85. Im running 555 also and making 307 kw. If you want to go down the sensor path its not as easy just hooking up the sensor. Youll also need a compatible ecu link, vipec etc. Theres a whole thread on it if you search.
Sorry mate, just read that Advan was doing the work.... if your wanting to get the ethanol sensor sorted out speak to Yavuz at Unigroup engineering. I have had brief talks about doing this to my car and Yavuz is all over it and has some ideas on how to tackle it. He knows his Links as well which is a plus
or go to JEM. they have fitted a number of cars with the zeitronix E content sensor (they are dealers for it). and tuned many cars on E85/Eflex etc now. I would talk to those guys.
I've got my GTR on E85 and i had changed injectors, added another fuel pump and retune.
seriously, there is no point running E85 for "safety" its costly to change injectors etc for little gains if your motor, turbo, AFM's or other gear are going to limit you to power you could easily achieve on PULP
i had my GTR running 21psi on PULP and getting 350rwkw, then went to E85, upped the boost to 24psi and got 370rwkw. the boost wont hold until redline it drops off to 20 or so PSI so that's why there is no huge gain in the top end. but midrange is crazy! and thats where most driving is done. torque difference is great.
then again, on my setup i was nearing the limit of PULP with the parts i had. if i had to do it again i probably wouldnt bother. the limited station and less ecconomy means with a spirited hills run i have a 20L jerry can in the boot just to make sure i don't run out of fuel.
for what you've listed, get your turbo, and injectors fitted and tuned on PULP and enjoy for a while and save up for E85 if you feel the need.
what turbos?
what turbos?
turbo's on mine are -5's
I'm thinking maybe an exhaust leak is contributing to the boost not holding at 24psi. because after a hard few goes at WOT on high boost i can hear a high pitched whistle coming from the engine anytime the turbo's spool.
i'm also getting very small amounts of blue smoke out the back of the muffler when i back off the throttle, some have suggested maybe turbo seals?
Hey cal spewing bout the turbo mate im not chasing that much power so i wont be too disappointed by not making that kinda power mate
So changing the front didnt get you more power mate?
ATM its a 3kw gain. But as I said I havent touched the timing really, just trimmed the AFR's to be alright.
So there might be a little more power in the tune, but the way I've modified it, it may have a slight leak so that could also be causing a loss in power (it is a temporary thing at the moment)
The main difference is overall driveability, it feels alot better on the street, slightly more responsive (not a great deal but) and I was having an issue with what sounded like surge at around 16psi in 5th gear (short version of what was happening) which has disappeared now.
So basically at the moment its an improvement. But its not on par with the Pro S
Yeah im thinking bang for my buck at the moment and since that i have my fuel injectors and other fuel system parts a servo a km away from my house that has E85 im thinkng once my turbo arrives and i install that and my fuel injectors Z32 afm im gunna need a tune anyways so its not gunna cost me any extra to run E85 and get the extra midrange plus the HP i was chasing with the Kai turbo kit since it doesnt seem to work as good as the Pro S kit that i just couldnt get my hands on! :domokun:
Lol thats ok mate if i go down the ethanol sensor and the link computer option i will prob get my link from Advan which im prob not gunna do now cos if my injectors will see my HP target im chasing ill be happy without spending the extra $$$$ and using the nistune
could be. still 350kw on pulp is right at the good end of power for -5s on 21psi so things seem fairly healthy. I would have expected a bit more like 380kw or so though with 3psi more boost AND E85 change. still I wouldn't be too concerned. fix the exhaust leak though, they certainly don't help.
Hrmmm whistling noise when the turbos are on boost..have a read of my thread from yesterday lol Mine was the gasket between the turbo and manifold :/
Im a bit annoyed with it really, I wanted to run 270rwkw on 98 and then when/if E85 ever comes out on pump where I live I was gonna have a "Race" E85 tune and then a daily tune that would run 270rwkw just on less boost.
At the moment Im just making 243rwkw on 18psi. Its disapointing seen as I ordered a Pro S at the time the started discontinuing them so I was told the KAI was just as good if not better. Doesnt seem to be the case
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
