I was talking to a bloke about this today and was thinking about getting the drifter re tuned for e85 but not sure if its worth it. currently only making 240rwhp on the rb20 with vg30 turbo on 15psi, all the usual bolt on mods but internally stock, stock afm and injectors, i am how ever running an intank 040 and an 044 with a surge. what kind of gains can i expect power wise changing from bp98 to e85 with the car exactly how it currently is?
Im at a cross roads now :ermm: ive been told that i will need 1000cc injectors for 270rwkw on E85! couple of lads in here claim to be running 550cc injectors and both are making over 300rwkw on E85
if i went for 1000cc injectors would i have to change my fuel rail too? I was told you use approximately 30% more E85 than 98.......:O
30% is pretty right. The tuning style also has a lot to do with what size injectors will be required. Running it lean with less timing will obviously mean you can get away with smaller injectors. Tuning rich with more timing obviously means larger injectors will be required.
They must be running them pretty lean to make 300rwkw on 550's
I was told today that my 550's will be ok for 270rwkw on E85 but they will be pretty clos to being at their limit by a nice gentleman from JEM so im gunna take his advice and bolt em in when my turbo comes :cheers:
damn some people must be tuning lean.... each to their own and everyone has a different philosophy though
Although i realise its a fair whack more power, my 1600's are at 90% at 460odd. That wil change soon though as the ID 1600's have been recalled so its up to 2000cc's :D
I am fairly sure the 2000's will have similar issues, especially on ethanol, as they are both natural gas injectors from what I'm told. The o-ring isn't rated for petrol (long term) and won't be warranted, especially with e85. If this is true the 1000's may be the only Bosch option.
I also have reservations on the spray pattern with the 2000's as the jellybean plate after the nozzle is designed to desperse the natural gas, not sure how it will work at high liquid fuel flow. Has anyone seen a video of the spray patterns on these injectors?
I'm doing a upgrade on my car I'm getting 2000 cc injectors .....haltec pro series ecu ..........and I have a.t88 on my gtr but I'm going a bit bigger I was thinking t 51r turbo my car.makes 700 HP at all wheels I want more power :-(
My car is not tuned lean with 555 to make 300 kw , its a very safe tune. But yeah in the end comes down to how the specific tuner tunes if he dorsnt believe he can get away with 555 then gota do whats hes confortable with.
What kinda turbo and boost are you running mate?
Ive gotta HKS 2835 kai coming and im hoping to push bout 16-18psi down my cars neck.
A guy off here who has the same turbo is only hitting 67% duty cycle on his 550's with 18psi boost
Im running a hypergear tr43i (the really really old model) I guess comparing it to power terms of a garett would be closet to a 3071. Im running 17.5 psi.
    • All I'm hearing is sequential swap time. Gives you a shifter, and crisp hard fast shifts. You can even use flappy paddles with them. You just can't give the shifter the side to side shake to make sure you're in neutral
    • HKS2530 frame and a newer CHRA plausible? like a g25-500 CHRA in the hks2530 frame?
    • Welcome back mate ,I also joined in the early 2000's , since then I have been in and out a few times depending if I had a skyline in the garage.  I have the another one now , so signed up and back with the SAU team.
    • I used "different strokes for different folks" quite pointedly as honestly, there is no wrong when it comes to choosing what you like.  I always day dreamed about flappy paddles with fast shifts in a sporty RWD Turbo and to me the sound and feel of it cutting through gears in a steady stream is exciting, engaging, and keeps the car better balanced - I *also* like h-patterns, but I find them more engaging and fun in a nice hoonable peaky NA thing.  Type-R Integra/old school NA rotary, things that are raw and need all the rpm where picking the gear and getting it sky high is part of the engagement of the whole thing despite the fact that they probably need closer ratios and faster shifts even more than a 3l turbo thing haha
    • If I wasn't allowed or really had the desire to visit China it would probably fit in my carry on, but I have no desire, Japan would be nice during Cherry Blossom time though I might need to chat to Jackie about that, that should actually be an easy conversation though as she is currently talking about another cruise, cruise ship to Japan, a week in Japan to see the sights, then cruise home I may even be able to find those OEM NC Recaro seats over there that I cannot find here 🤔
