hey guys,
thought someone might know a little about these, bought a new blitz intercooler kit on the cheap as it come with no instructions and a silicon missing. silicon was easy to obtain but the instrustion being gone and my inability to wing it like i thought i would have me a little lost, below is a pic of all the bracketry that come with the kit and also a pic of the front of my car. if possible could someone please point out what goes where.
cheers adam
p.s. i have also posted this on ns.com but was hoping for a faster response on here as im mid assembly
https://www.sau.com.au/forums/topic/372291-blits-s13-intercooler-install-help/
No idea on a Silvia but generally hoses will dictate where the i/c sits and then you look to see where brackets can attach. If its not a custom set up you may need to bend brackets, make up new ones or weld mounting tabs.
I like the cooler as high as I can mount it, right up close to the lights.
The pipework will fall into place.
I made my own brackets for the bottom, ground off the two top tapping blocks and used a single mount at the centre instead which raised it up approx 25-30mm.
The black chassis car is showing the position for standard brackets.
