I've searched on this site for my problem and there seem to be similar symptoms around but not exactly the ones I’m experiencing.
When I cold start 75% of the time my car will stay at around 400RPM like it’s about to stall. If I ever so slightly touch the accelerator the car will bring itself up to the normal 1500RPM.
In addition I’ve seen a lot of problems with people's cars missing at 5000 RPM. My car doesn't miss at 5000RPM but looses power after 6000RPM. I am getting full boost fine at 5000 RPM.
My cars only mods are pod filter, exhaust and large intercooler. The car is not running an aftermarket boost controller, so it’s just standard boost.
I'm going to take this car to a mechanic but wondered if there was something I could do myself to save money.
I have completed an ECU diag, changed spark plugs, fuel filter, cleaned airflow meter to no avail.
https://www.sau.com.au/forums/topic/37237-weird-cold-start/
Thanks. I've got a feeling it might be some kind of injector issue, but im only guessing.
Ask the Mechanic to checkout if its one of these 2 problems.
Possible Leaking injector..
Aire in your fuel line.
As i have a similar problem on a cold start. let me know how it goes..
https://www.sau.com.au/forums/topic/37237-weird-cold-start/#findComment-746405
Thanks for your reply. I'm not to sure what TPS or AAC stands for. When i cold start the car is strugles to get above 400 RPM, but if you leave it long enough it suddenly jumps to 1500 RPM... If i slightly push the accelerator pedal this causes the car to jump to 1500 RPM also...
So it sounds like both idles are set where they should be.
Sorry for appearing car 'stupid'.
hv u check the TPS, thorttle & your Fast idle ctrl? there are 2 plugs on the AAC value.. the upper 1 is fast idle & the other 1 is normal idle.
https://www.sau.com.au/forums/topic/37237-weird-cold-start/#findComment-748286
hey mate, you see in that photo that block of alloy with the gaskit inbetween it and the manifold, well that alloy block is the aac valve assembly, there is a a few bolts holding it on, unbolt them it wall fall strait off, once you do this you will see the little valve on the inside, give it a good blast with carb cleaner,
sorry about the engrish,
https://www.sau.com.au/forums/topic/37237-weird-cold-start/#findComment-750792
Thanks, I'll give it a go...
https://www.sau.com.au/forums/topic/37237-weird-cold-start/#findComment-753586
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
