Hi All,
Can anyone point me to a good panel shop, have an issue where bonet is closing crook due to one of the panels being pushed. F me if I knew how it got that way, it looks as if someone has actualy kicked it or reversed into it with decent force - theres a decent dent near the light. Anyway I am realy pissed off about it because bonet is constantly in contact with the side 1/4 panel and if you ride a speed bump or driveway fast enough it will make a rubbing noise.
Shgould I just go to any place? the last place I went to and said can you fix my sagging front bumper they told me to diy - in otherwords piss off, too small & troublesome.
Location would help.
But I would do as the last place said, DIY. Panel beating isn't difficult, you just have to be careful. I'm sure they would have taken your money if you had insisted, but you gotta realize that it is a small job and it means they have your car in there taking up the space that a 'more profitable' car could occupy. That means that if you do insist you want them to do it, they will charge a hell of a lot more than it is worth because they will see it as costing them money.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
