  • Replies 44
Mine has 25,000k's on the odo now. ;) I still have the original I can give the next buyer but I don't think they will care. Its obvious an aftermarket Nismo dash will change the K's isnt it?
I didn't think so. I actually figured in a car this new it'd be harder to alter the k's than this.
"This new"?
You don't need a new dash to alter the odo reading either.
There was a simple plug and edit thingo on Yahoo not long ago that allowed the user to select what kms they wanted the odo to display.
Was repeatedly for sale for around $40 + shipping/commission if I recall correctly.
Dunno if they had to take the dash out, but I'd imagine so.
At least with the old odo's, you could tell when they had been wound back as the numbers wouldn't line up properly.
    • Yeah, whenever I say "HP", I mean HP. As in, at the engine. Allowing for a 25% discount from engine to typical Ozzie braked roller dyno figures, then subtracting the usual (more optimistic) US inertia dyno offset..... you get into the 600 actual engine HP territory from your 484 wheel number. 484 / 0.75 = 645   (that's Aussie rw intertia HP, converting to approximate engine HP. 645 --> 600 is discount for inertia dyno. Could actually be worse than that. But that would still be up around 600. So near enough for purposes.
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
