  • Replies 44
Cluster comes with 147Km on odo. Just goes to show how far wound back most cars are that are sold here (assuming fairly typical distance travelled). Having said that, I don't particularly want my car having an extra 50K added to the odometer. Then you got to explain to everyone who looks at it... lol
well your probably aware that 87-90 degrees of water is normal for our car.
its just how thin the radiator is and the load on it.
bigger radiator to take the load for winter will far out do the thermostat, especially if it ends up being too cold and keeps the car is a cold start map lol
Don't confuse the Nismo thermostat (which doesn't do that) with the Mishimoto thermostat (which does do that).
Bigger radiator would be more beneficial in the summer you'd think, yes?
yeh but there is a lower temp nismo thermostat available. isnt there?
i duno what your trying to get at
I thought Nismo was lower than stock, and Mishimoto was lower again.
Thought I read a thread on here where Scott fitted the Mishimoto and it was too cold and stuffed the car around, but I haven't seen much on the Nismo?
I run a 54mm race radiator and the Nismo thermostat.......no problems with my car with normal running in winter.....it hangs around 85 to 89 in traffic and about 84 on the freeway on hot or cold days....pretty sure from memory it was the same in summer.
On the track it dropped down 2 degrees and ran a perfect 83 degrees the whole time.......makes me think that it would do about 85-86 degree's in summer on the track!
Edited by Jetwreck
Ahh too late sold it to Whiteaxis...LOL
Below would be what I am getting at, thanks Ryan.
You don't really hear anything about them because the Nismo just works.
no you can legally change them over and report the change, to be honest i dont know whats involved. mine was only a few thousand off so i didnt bother
Mine has 25,000k's on the odo now. ;) I still have the original I can give the next buyer but I don't think they will care. Its obvious an aftermarket Nismo dash will change the K's isnt it?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
