  • Replies 44
Mine has 25,000k's on the odo now. ;) I still have the original I can give the next buyer but I don't think they will care. Its obvious an aftermarket Nismo dash will change the K's isnt it?
I didn't think so. I actually figured in a car this new it'd be harder to alter the k's than this.
"This new"?
You don't need a new dash to alter the odo reading either.
There was a simple plug and edit thingo on Yahoo not long ago that allowed the user to select what kms they wanted the odo to display.
Was repeatedly for sale for around $40 + shipping/commission if I recall correctly.
Dunno if they had to take the dash out, but I'd imagine so.
At least with the old odo's, you could tell when they had been wound back as the numbers wouldn't line up properly.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
