hey all, dont know if you guys have ever had this problem, i cant hit rev limiter, i can hit 5500rpm and then the car just dies, throttle wide open, boost drops to 0 and car stops driving but still keeps revs to 5500rpm, the engine just stops pushing........no boost no pull no nothing, just stays there, with foot to the floor.
cant for the life of me figure out what it is.
but sometimes it does go away, but instead, at 5500rpm it cuts out for 2 seconds and then just keeps going as if nothing happened..
any helpful info would be great.
RB25 neo motor, no TCS in the car all stock besides exhaust and coilpacks.
https://www.sau.com.au/forums/topic/372403-problem-with-rb25-neo/
yeah i got stock ecu too wit mild mods and my ecu
freaks out when i try tap into the boost i even tryed resettin it
but when i put a nistune in it runs sick
^^ or ya spark is breakin down coilpacks plugs
but generally when that happens its more of a stutter than a
complete cut
no fuel cut though, it doesnt cut out, it just stops accelerating. boost drops, and it will just stay at 5500rpm, wont drop below that and wont go above that... bloody weird, cleaned AFM, new plugs, and new coils. checked for any leaks, nothing. reset ecu, nothing... im lost now.
if i didnt just get fired, id opt for a Power FC, but gotta save money now.
sticking wastegate maybe?????
also just found this out, it has one of 2 problems,
Problem 1: any gear it wont rev up past the 5-6k mark but if it does manage to rev normally, problem 2 occurs
Problem 2: 1st gear, revs and hits boost and its all normal, hit 2nd and it has a 1 second cutout at 5-6k rpm, change to 3rd and it will continually cut out 5-6k rpm...... and same in 4th, cant hit above 5k rpm in 5th, it can only get to 180kmh
so if its not problem 1 its problem 2...... pissing me off!!!!!! RAAAAGE QUIT!!!!
oh, bad news for me today, i decided to install a boost gauge today to see what the turbo is running, as we all know i cant read or make out what the stock boost gauge says, it says -7 all the way to +7 mmhg, so connected the new gauge which is psi, i plugged it in between the manifold and purge valve, and took the car for a run, the boost gauge hit 13psi at 5000rpm in first and hit 15.5psi in 2nd and 16psi in 3rd. so if this is anything to go by, im pretty screwed.
all i did was disconnect the boost solenoid and did the constant 7psi trick as talked about, or so i hoped. guess it seems to be a 15psi trick instead.....
just changed back to original solenoid, and it runs back at normal PSI, 350mm/hg which is 6.8psi, so the original boost gauge is pretty spot on. before it went beyond the +7 on the boost gauge (700mm/hg= 13.5psi) damn!
so the 2 pipes that go into the solenoid, i originally bypassed, hose-solenoid-hose, i bypassed that and just connected the 2 hoses directly without the solenoid in the middle. thought it would just sit at 7psi like people said it would, but it didnt did it??
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
