hey all, dont know if you guys have ever had this problem, i cant hit rev limiter, i can hit 5500rpm and then the car just dies, throttle wide open, boost drops to 0 and car stops driving but still keeps revs to 5500rpm, the engine just stops pushing........no boost no pull no nothing, just stays there, with foot to the floor.
cant for the life of me figure out what it is.
but sometimes it does go away, but instead, at 5500rpm it cuts out for 2 seconds and then just keeps going as if nothing happened..
any helpful info would be great.
RB25 neo motor, no TCS in the car all stock besides exhaust and coilpacks.
https://www.sau.com.au/forums/topic/372403-problem-with-rb25-neo/
yeah i got stock ecu too wit mild mods and my ecu
freaks out when i try tap into the boost i even tryed resettin it
but when i put a nistune in it runs sick
^^ or ya spark is breakin down coilpacks plugs
but generally when that happens its more of a stutter than a
complete cut
no fuel cut though, it doesnt cut out, it just stops accelerating. boost drops, and it will just stay at 5500rpm, wont drop below that and wont go above that... bloody weird, cleaned AFM, new plugs, and new coils. checked for any leaks, nothing. reset ecu, nothing... im lost now.
if i didnt just get fired, id opt for a Power FC, but gotta save money now.
sticking wastegate maybe?????
also just found this out, it has one of 2 problems,
Problem 1: any gear it wont rev up past the 5-6k mark but if it does manage to rev normally, problem 2 occurs
Problem 2: 1st gear, revs and hits boost and its all normal, hit 2nd and it has a 1 second cutout at 5-6k rpm, change to 3rd and it will continually cut out 5-6k rpm...... and same in 4th, cant hit above 5k rpm in 5th, it can only get to 180kmh
so if its not problem 1 its problem 2...... pissing me off!!!!!! RAAAAGE QUIT!!!!
oh, bad news for me today, i decided to install a boost gauge today to see what the turbo is running, as we all know i cant read or make out what the stock boost gauge says, it says -7 all the way to +7 mmhg, so connected the new gauge which is psi, i plugged it in between the manifold and purge valve, and took the car for a run, the boost gauge hit 13psi at 5000rpm in first and hit 15.5psi in 2nd and 16psi in 3rd. so if this is anything to go by, im pretty screwed.
all i did was disconnect the boost solenoid and did the constant 7psi trick as talked about, or so i hoped. guess it seems to be a 15psi trick instead.....
just changed back to original solenoid, and it runs back at normal PSI, 350mm/hg which is 6.8psi, so the original boost gauge is pretty spot on. before it went beyond the +7 on the boost gauge (700mm/hg= 13.5psi) damn!
so the 2 pipes that go into the solenoid, i originally bypassed, hose-solenoid-hose, i bypassed that and just connected the 2 hoses directly without the solenoid in the middle. thought it would just sit at 7psi like people said it would, but it didnt did it??
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
