hey all, dont know if you guys have ever had this problem, i cant hit rev limiter, i can hit 5500rpm and then the car just dies, throttle wide open, boost drops to 0 and car stops driving but still keeps revs to 5500rpm, the engine just stops pushing........no boost no pull no nothing, just stays there, with foot to the floor.
cant for the life of me figure out what it is.
but sometimes it does go away, but instead, at 5500rpm it cuts out for 2 seconds and then just keeps going as if nothing happened..
any helpful info would be great.
RB25 neo motor, no TCS in the car all stock besides exhaust and coilpacks.
https://www.sau.com.au/forums/topic/372403-problem-with-rb25-neo/
yeah i got stock ecu too wit mild mods and my ecu
freaks out when i try tap into the boost i even tryed resettin it
but when i put a nistune in it runs sick
^^ or ya spark is breakin down coilpacks plugs
but generally when that happens its more of a stutter than a
complete cut
no fuel cut though, it doesnt cut out, it just stops accelerating. boost drops, and it will just stay at 5500rpm, wont drop below that and wont go above that... bloody weird, cleaned AFM, new plugs, and new coils. checked for any leaks, nothing. reset ecu, nothing... im lost now.
if i didnt just get fired, id opt for a Power FC, but gotta save money now.
sticking wastegate maybe?????
also just found this out, it has one of 2 problems,
Problem 1: any gear it wont rev up past the 5-6k mark but if it does manage to rev normally, problem 2 occurs
Problem 2: 1st gear, revs and hits boost and its all normal, hit 2nd and it has a 1 second cutout at 5-6k rpm, change to 3rd and it will continually cut out 5-6k rpm...... and same in 4th, cant hit above 5k rpm in 5th, it can only get to 180kmh
so if its not problem 1 its problem 2...... pissing me off!!!!!! RAAAAGE QUIT!!!!
oh, bad news for me today, i decided to install a boost gauge today to see what the turbo is running, as we all know i cant read or make out what the stock boost gauge says, it says -7 all the way to +7 mmhg, so connected the new gauge which is psi, i plugged it in between the manifold and purge valve, and took the car for a run, the boost gauge hit 13psi at 5000rpm in first and hit 15.5psi in 2nd and 16psi in 3rd. so if this is anything to go by, im pretty screwed.
all i did was disconnect the boost solenoid and did the constant 7psi trick as talked about, or so i hoped. guess it seems to be a 15psi trick instead.....
just changed back to original solenoid, and it runs back at normal PSI, 350mm/hg which is 6.8psi, so the original boost gauge is pretty spot on. before it went beyond the +7 on the boost gauge (700mm/hg= 13.5psi) damn!
so the 2 pipes that go into the solenoid, i originally bypassed, hose-solenoid-hose, i bypassed that and just connected the 2 hoses directly without the solenoid in the middle. thought it would just sit at 7psi like people said it would, but it didnt did it??
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
