You need a head torch and/or other work light, a (I think) 10mm open ended spanner, nimble fingers or pointy nose pliers, or a specially made (by you) tool from a bit of bent sheetmetal with a notch cut in it to match the size of the flat on the clutch pedal push rod. Lie on your back, upside down under the steering wheel. Find the clutch push rod where it goes from the back of the pedal through the firewall. There is a lock nut around this rod located behind the back of the pedal. Loosen the locknut. Then you can rotate the rod to adjust the pedal freeplay. If you reduce the amount of rod sticking out the front side of the pedal, then you will lift the pedal off the floor.
BUT. BIG BUT. If you have to adjust the rod so far that there is no rod sticking out the front, and you still don't have a good pedal, then it is quite likely that your clutch master cylinder is buggered and you need a new one. Adjusting the pedal is only a bandaid where you have other real problems.
12mm spanner, not 10mm
And yes, it's about getting the correct freeplay, not just getting it where you want it.
If you have a broken pedal box, buggered hydraulic system or a poorly adjusted pedal, then it has other issues.
Don't forget that too far in the adjustment will cause just as many problems as not enough adjustment so only make small adjustments ie: 1 rotation of the rod, so that you don't go too far before it's too late
also i think i should check its bled properly.
tips on bleeding it?
do you bleed from the cyl on the box or the cyl where the fluid is?
If you are just letting the fluid drip out of the nipple, you're doing it wrong.
I don't give two shits what anyone says but you SHOULD ALWAYS put a clear piece of tubing over the nipple and place it in a jar ABOVE the lowest point(or on the ground I cant remember haha).
I spent about a day trying to bleed my clutch after I changed it. Couldn't do it. Had to press the clutch all the way down and it still wouldn't feel right. Called lube mobile, they didn't take money coz he couldn't fix it and said my fork was broken. My old man neighour came past, asked what I was doing and I told him. He said I was doing it all wrong and without the pipe you will not see how much air is coming out and you also raise the chance of air going back into the system. 10 minutes later my pedal was perfect. That little screw won't really do shit about your bite point. Its more to adjust freeplay. If you have ALOT of travel that does nothing right until the last dead point of the pedal, clearly you have another issue in the system... Ive got about an inch before I can feel my clutch pulling and then the whole way to the floor is just.... normal I guess.
  • 3 weeks later...
Incorrect pushrod length maybe?
Or, if you have done the conversion and kept the same master cylinder but let it go dry, you need to bleed that master cylinder properly first, before ANY fluid will go through the rest of the lines.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
