hi guys,
Forgive me for posting this here but i figure someone will be able to point me in the right direction or have some suggestions...
Cutting a long story short, I'm in the process of fixing up a 1998 VW Polo for a friend of mine for his 18th birthday. It was originally mine before a kangaroo sat on it. I found a 2nd hand silver guard for it which once mounted is 'close' in that its silver and that's about it :) I still need to get a bonnet, but if I do, what would be an economical way to have it painted, because after all we are talking about a VW Polo here whose total net worth would be close to that of a full tank of petrol, but they're safe, frugal and cheap to insure :)
I rang the local panel shop that fixed up our farm landcruiser and he was talking about $600+ which I must admit is more than I realistically wanted to spend. I'd like to spend between the $200-$300 is possible and any service that i could provide in return (I'm in IT for 7-Eleven HQ, so slurpee vouchers are a given :)). I should point out that I'm not super fussed at the quality of the job but something close would be nice. It doesn't have to last forever as its a first car.
There are a few options i have for the bonnet, being a new Taiwanese, 2nd hand VW in another colour from a wrecker or a brand new VW one ($220,$240 and $440 respectively).
If I was going to have the bonnet painted and it was not going to be a LOT more, I picked up a new original VW guard from ebay a few months ago (for $10), that while the painting is being done, may make economical sense to have painted too?
I'm open to ways of doing it, as in I can take the old guard I took off along with the new guard and a bonnet to someone to match it as much as possible, they can do it at my place (have a big shed and plastic) then thats okay too. The car is no longer registered so it would be a little hard to get it somewhere, but of course wouQld do so if requires. I understand that makes blending difficult but for the price I want to pay, I dare say its not something that I would be getting anyway
Any thoughts / suggestions or directions would be greatly appreciated. Thanks again!
2 die 4 Bodyworks
38a Lipton drv, Thomastown
0424 265 134
owners name is Craig, tell him stefan with the GTR sent you and explain your situation (not expecting to much ect)... should be able to help you
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
