hi guys. just got my skyline back today. its a rb25-30 motor. standard head, standard rods and new cast mahle pistons.
he said he did one pull only on it after tuning. it made 450rwhp on 17.5psi and blew heaps of smoke out the back (think he said that) and was coming out the breathers on the engine.
he said the pistons would be fine for it (i already had the motor done and all that). after i got it home my engine bay is covered in oil from the breathers. (didnt have catch can on yet, just open breather pipes
if it turns out to be from detonation can i make him pay for new motor?
Edited by joe blo
https://www.sau.com.au/forums/topic/372437-new-engine-blown-up-at-tuners/
  • Replies 218
Posted Images
Is it actually broken (eg rattles and clunks) or is it fine except for oil coming out of the breathers?
no rattle and clunk noises im pretty sure. runs abit rough on idle and its different to start then before. hard to start but does go
has the 2 1.5mm oil restrictors put in and spool oil drain back kit for rear of head
what are you thinking? hope it may just be broken ring
Edited by joe blo
just a receipt from when i paid. about 4 weeks ago i got the car back. car wouldnt rev over 4500 in neutral and boost cut would hit at about 4000rpm if you could rev it that far and had boost cut from ecu at 20 psi. i had to ge the car back and take the wastegate off myself and fix the thread for the hose then put it on and go back to get the tune finished. in that time i put a 50mm gate on instead now but. today was the finish tune day
What is this..... america???
You'r playing with modified engines... it happens. If you think your tuner did somthing wrong, don't take the next one to them..
Or was it the engine builder?
Or the injector manufactuer
Or the spark plug factory
oooor maybee it was the sneaky fuel supplier
hang on.. I have it-
Mr spanky with a candle stick holder in the sitting room.
This is some sort of Friday afternoon joke right?
Any tuner can only do his best with what he's given. If the setup (hardware inside engine) was crap before it got there, it wont magically get fixed on the dyno.
I was going to say that if its still running fine and not making any noises then it may be a lack of oil control thats got you so concerned
ah forgot that part. i put the crank in myself and couldnt get the rods and pistons in so got them put in at machining shop. then picked it up and assembled the rest myself
How was the motor run in?
Did the machine shop actually measure all the tolerances and so on, or simply assemble and return (which assumes you measured it all up).
cool. hopefully thats the case.
the problem will be shown when its pulled apart yes? it wont be mystery failure form me putting it together?
If it's pulled apart by a professional, then yes.
By the sound of it, and no offence, if you DIY you aren't going to find out.
motor was run in on dyno by tuner guy.
the machine shop bored the block and supplied the pistons. and they measured the bearings and provided the ones i needed
the standard rb25 i pulled out had 6 broken pistons and didnt make ANY bad noises. drove it for like 1.5 years as a smoke machine and it made 250rwhp smoking HEAPS
if its from poor assembly i totally accept it. it was a learning thing. if its from me i dont think il bother learning anymore lol.
the big thing for me was going to be if it even started and worked properly in the first place. lol
after the first startup and first tuning went well i was convinced i had done a good job done properly
Edited by joe blo
Tell me which tuner in their right mind would pay for someones engine if it broke on the dyno? Almost anyone can slap a motor together and have it last for a couple of runs/weeks. You gotta know more about engine building than just bolting it together with the right torque settings.
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
