hi guys. just got my skyline back today. its a rb25-30 motor. standard head, standard rods and new cast mahle pistons.
he said he did one pull only on it after tuning. it made 450rwhp on 17.5psi and blew heaps of smoke out the back (think he said that) and was coming out the breathers on the engine.
he said the pistons would be fine for it (i already had the motor done and all that). after i got it home my engine bay is covered in oil from the breathers. (didnt have catch can on yet, just open breather pipes
if it turns out to be from detonation can i make him pay for new motor?
Edited by joe blo
https://www.sau.com.au/forums/topic/372437-new-engine-blown-up-at-tuners/
  • Replies 218
Posted Images
Is it actually broken (eg rattles and clunks) or is it fine except for oil coming out of the breathers?
no rattle and clunk noises im pretty sure. runs abit rough on idle and its different to start then before. hard to start but does go
has the 2 1.5mm oil restrictors put in and spool oil drain back kit for rear of head
what are you thinking? hope it may just be broken ring
Edited by joe blo
just a receipt from when i paid. about 4 weeks ago i got the car back. car wouldnt rev over 4500 in neutral and boost cut would hit at about 4000rpm if you could rev it that far and had boost cut from ecu at 20 psi. i had to ge the car back and take the wastegate off myself and fix the thread for the hose then put it on and go back to get the tune finished. in that time i put a 50mm gate on instead now but. today was the finish tune day
What is this..... america???
You'r playing with modified engines... it happens. If you think your tuner did somthing wrong, don't take the next one to them..
Or was it the engine builder?
Or the injector manufactuer
Or the spark plug factory
oooor maybee it was the sneaky fuel supplier
hang on.. I have it-
Mr spanky with a candle stick holder in the sitting room.
This is some sort of Friday afternoon joke right?
Any tuner can only do his best with what he's given. If the setup (hardware inside engine) was crap before it got there, it wont magically get fixed on the dyno.
I was going to say that if its still running fine and not making any noises then it may be a lack of oil control thats got you so concerned
ah forgot that part. i put the crank in myself and couldnt get the rods and pistons in so got them put in at machining shop. then picked it up and assembled the rest myself
How was the motor run in?
Did the machine shop actually measure all the tolerances and so on, or simply assemble and return (which assumes you measured it all up).
cool. hopefully thats the case.
the problem will be shown when its pulled apart yes? it wont be mystery failure form me putting it together?
If it's pulled apart by a professional, then yes.
By the sound of it, and no offence, if you DIY you aren't going to find out.
motor was run in on dyno by tuner guy.
the machine shop bored the block and supplied the pistons. and they measured the bearings and provided the ones i needed
the standard rb25 i pulled out had 6 broken pistons and didnt make ANY bad noises. drove it for like 1.5 years as a smoke machine and it made 250rwhp smoking HEAPS
if its from poor assembly i totally accept it. it was a learning thing. if its from me i dont think il bother learning anymore lol.
the big thing for me was going to be if it even started and worked properly in the first place. lol
after the first startup and first tuning went well i was convinced i had done a good job done properly
Edited by joe blo
Tell me which tuner in their right mind would pay for someones engine if it broke on the dyno? Almost anyone can slap a motor together and have it last for a couple of runs/weeks. You gotta know more about engine building than just bolting it together with the right torque settings.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
