Hey All,
I'm in the North Brisbane Area 4017
Up for sale is my '94 R33 Gtst coupe auto.
Looking for $5000 NEG - No RWC
Here is a few things about it.
~248K on it
comes with:
  • APEXI SAFC fitted
  • manual under bonnet boost adjust
  • Genuine skyline front floor mats (average condition)
  • Spare rear wing (needs paint)
  • spare alternate style front bumper (also needs paint - the guy who owned it before me was going to use it for FMIC)
  • Remus exhaust 3" cat back with a split dump pipe.
  • SONY 7" DVD player and media centre. with iPod connector in centre console
  • also comes with lots of receipts from work done since import and import receipts and such
  • New battery in March
  • K&N panel filter with filter charge kit.
My list of things i Know are not right
  • Will need new tyres for road worthy
  • the aircon doesn't work (i believe it just needs a re-gas)
  • both doors have damaged paint
  • driver's seat has the usual tear in it on the right side support
  • one wheel rim is damaged but they are el cheapo ones anyway
  • front left of bumper has some paint scuffed off.
this car has been good to me and a lot of fun but its time for something more sensible (need to slow down till my points catch up)
since i have owned it at around 215K it has had an oil and oil filter change carried out every 5K
fuel filter change carried out every 15K and when i bought it.
previous owner only ran it on ultimate. i only run it on vortex 98.
mainly highway driving for me commuting as well.
kept in the garage at home.
any other questions i'm more than happy to answer
Email: [email protected]
Phone: 0431 082 447
Cheers, Willy
P.S. Will post more photos over the weekend.
Edited by wacky_will
https://www.sau.com.au/forums/topic/372457-94-r33-gts-t-for-sale/
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
