Hey All,
I'm in the North Brisbane Area 4017
Up for sale is my '94 R33 Gtst coupe auto.
Looking for $5000 NEG - No RWC
Here is a few things about it.
~248K on it
comes with:
  • APEXI SAFC fitted
  • manual under bonnet boost adjust
  • Genuine skyline front floor mats (average condition)
  • Spare rear wing (needs paint)
  • spare alternate style front bumper (also needs paint - the guy who owned it before me was going to use it for FMIC)
  • Remus exhaust 3" cat back with a split dump pipe.
  • SONY 7" DVD player and media centre. with iPod connector in centre console
  • also comes with lots of receipts from work done since import and import receipts and such
  • New battery in March
  • K&N panel filter with filter charge kit.
My list of things i Know are not right
  • Will need new tyres for road worthy
  • the aircon doesn't work (i believe it just needs a re-gas)
  • both doors have damaged paint
  • driver's seat has the usual tear in it on the right side support
  • one wheel rim is damaged but they are el cheapo ones anyway
  • front left of bumper has some paint scuffed off.
this car has been good to me and a lot of fun but its time for something more sensible (need to slow down till my points catch up)
since i have owned it at around 215K it has had an oil and oil filter change carried out every 5K
fuel filter change carried out every 15K and when i bought it.
previous owner only ran it on ultimate. i only run it on vortex 98.
mainly highway driving for me commuting as well.
kept in the garage at home.
any other questions i'm more than happy to answer
Email: [email protected]
Phone: 0431 082 447
Cheers, Willy
P.S. Will post more photos over the weekend.
Edited by wacky_will
https://www.sau.com.au/forums/topic/372457-94-r33-gts-t-for-sale/
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
