Hey guys,
I got my mate to buy me my gearbox and doff oil but he bought me all lightweight when I asked for heavy duty for my diff oil zzz
Should I replace the diff oil for heavy weight or is light weight fine??
I'm taking it to the track in a month and want it to be the right stuff.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
