i got a weird problem with my rb20 ignitor dieing after i switch the car off and on again. i took the sparks and coils out and rested them on the block and spun the CAS by hand and i got no spark. so i went to the wreckers and got a 2nd hand ignitor and plugged it in and spun the CAS again. this time i got spark. so i put the car back together and started it up without a problem. i switched it off and tried starting it again - no spark WTF!
the CAS is working and the ECU is sending a signal for the sparks to fire and the coils are getting 12V and an earth. so i think ive narrowed it down to the ignitor
any ideas on how to fix this? is the r33 ignitor more reliable?
random pic of what an ignitor looks like on the inside
https://www.sau.com.au/forums/topic/372482-rb20-ignitor-fails-constantly/
ignitors are still frying. i took an ignitor that has been in my car and put it into someone elses car and their car didnt work.... the car runs fine witha new ignitor, but then i switch it off and switch it on again and the ignitor is fried
i measured the resistances of all earth wires and they all looked good, so i didnt bother beefing them up any more
i ended up making an ignitor with bits from jaycar. first attempt was a learning curve, as was attempt no.2, 3, 4, 5, 6, 7 etc. finally i found a configuration that sorta worked but found that transistor 1 and 3 fried after a short period of time. my ems stinger runs a wasted spark, so i removed transistors 1, 2 and 3 and linked transistors 4, 5 and 6 in their place. the problem seems to be solved but ill have to test it some other time. its midnight now and i think all the backfiring from the flooded engine is pissing people off. i hope its flooded anyways. either that or the spark isnt strong enough and i dont wanna increase dwell and fry something
i dont believe the ems stinger is to blame otherwise transistors 4 and 6 would have fried too (wasted spark). i think the problem lies in the loom. even though i couldnt pick up any reading from the signal wires (6 pin side of the ignitor) on the multimeter or oscilloscope, i think that somehow, a power source was coming from somewhere and causing the base of the transistors to stay 'ON', causing them to overheat from the charge of the primary winding of the coils. having said that i still have no conclusions as to why it would only die after i tried starting the car again, only theories
if all goes well i think i might start selling my little creations. and as far as i can tell, they will work on any car that runs an external ignitor just as long as you get the pins right. cheaper than any new or second hand ignitor and takes a lot more shit. its repairable, lighter and versatile... its just better
Edited by markdem
dunno what a jobby is... it is piggybacking if thats what you mean. and it was done by previous owners
the issue randomly came about one day. simply didnt start. i used the down time to put a new engine in and after completion it started up as soon as i turned the key. then 2 days later it wouldnt start and its stayed that way since
dwell time is not excessive at 2.75ms and if it were, it would cause all of the ignitors to fail, not just the ones connected to ignitor pinouts (pin-ins?) 1 and 3
found another clue as to why it wont start. im still getting spark when i spin the cas by hand, but as soon as i use the starter motor, the spark disappears. hence the original problem. im not good enough with electrics to fix this one myself. im sending it to a shop.
Edited by markdem
got the ecu tested by the main EMS guys in sydney. they say its ok. f**king electrician. i made my own loom to the starter motor and ignitors and hey presto! the car gets a spark when i turn the starter motor :) yay!
now i just cant get the thing to start. it puffs and backfires and gives an occasional powerstroke. im gonna steal the compression tester from work and test out compression again just incase something went bad.
my only question is: is it easier to ignite a rich or a lean fuel mix?
i plan on messing around with the fuel ratios a bit to aid in getting the engine started. im leaning towards a rich fuel mix coz on the old carby cars you had to pull the choke sooooo.... yeah just fiddling. i know, i know i shouldnt have to adjust fuel air ratios at all - especially considering that the engine already started several times on the current fuel air settings
Edited by markdem
Replace the spark plugs first before messing with the tune. Chances are that because u had no spark with u ignitor issues the plugs are fouled. Check them and see.
Also its easier to ignite a stoich mix :D
  • 1 year later...
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
