i got a weird problem with my rb20 ignitor dieing after i switch the car off and on again. i took the sparks and coils out and rested them on the block and spun the CAS by hand and i got no spark. so i went to the wreckers and got a 2nd hand ignitor and plugged it in and spun the CAS again. this time i got spark. so i put the car back together and started it up without a problem. i switched it off and tried starting it again - no spark WTF!
the CAS is working and the ECU is sending a signal for the sparks to fire and the coils are getting 12V and an earth. so i think ive narrowed it down to the ignitor
any ideas on how to fix this? is the r33 ignitor more reliable?
random pic of what an ignitor looks like on the inside
https://www.sau.com.au/forums/topic/372482-rb20-ignitor-fails-constantly/
ignitors are still frying. i took an ignitor that has been in my car and put it into someone elses car and their car didnt work.... the car runs fine witha new ignitor, but then i switch it off and switch it on again and the ignitor is fried
i measured the resistances of all earth wires and they all looked good, so i didnt bother beefing them up any more
i ended up making an ignitor with bits from jaycar. first attempt was a learning curve, as was attempt no.2, 3, 4, 5, 6, 7 etc. finally i found a configuration that sorta worked but found that transistor 1 and 3 fried after a short period of time. my ems stinger runs a wasted spark, so i removed transistors 1, 2 and 3 and linked transistors 4, 5 and 6 in their place. the problem seems to be solved but ill have to test it some other time. its midnight now and i think all the backfiring from the flooded engine is pissing people off. i hope its flooded anyways. either that or the spark isnt strong enough and i dont wanna increase dwell and fry something
i dont believe the ems stinger is to blame otherwise transistors 4 and 6 would have fried too (wasted spark). i think the problem lies in the loom. even though i couldnt pick up any reading from the signal wires (6 pin side of the ignitor) on the multimeter or oscilloscope, i think that somehow, a power source was coming from somewhere and causing the base of the transistors to stay 'ON', causing them to overheat from the charge of the primary winding of the coils. having said that i still have no conclusions as to why it would only die after i tried starting the car again, only theories
if all goes well i think i might start selling my little creations. and as far as i can tell, they will work on any car that runs an external ignitor just as long as you get the pins right. cheaper than any new or second hand ignitor and takes a lot more shit. its repairable, lighter and versatile... its just better
Edited by markdem
dunno what a jobby is... it is piggybacking if thats what you mean. and it was done by previous owners
the issue randomly came about one day. simply didnt start. i used the down time to put a new engine in and after completion it started up as soon as i turned the key. then 2 days later it wouldnt start and its stayed that way since
dwell time is not excessive at 2.75ms and if it were, it would cause all of the ignitors to fail, not just the ones connected to ignitor pinouts (pin-ins?) 1 and 3
found another clue as to why it wont start. im still getting spark when i spin the cas by hand, but as soon as i use the starter motor, the spark disappears. hence the original problem. im not good enough with electrics to fix this one myself. im sending it to a shop.
Edited by markdem
got the ecu tested by the main EMS guys in sydney. they say its ok. f**king electrician. i made my own loom to the starter motor and ignitors and hey presto! the car gets a spark when i turn the starter motor :) yay!
now i just cant get the thing to start. it puffs and backfires and gives an occasional powerstroke. im gonna steal the compression tester from work and test out compression again just incase something went bad.
my only question is: is it easier to ignite a rich or a lean fuel mix?
i plan on messing around with the fuel ratios a bit to aid in getting the engine started. im leaning towards a rich fuel mix coz on the old carby cars you had to pull the choke sooooo.... yeah just fiddling. i know, i know i shouldnt have to adjust fuel air ratios at all - especially considering that the engine already started several times on the current fuel air settings
Edited by markdem
Replace the spark plugs first before messing with the tune. Chances are that because u had no spark with u ignitor issues the plugs are fouled. Check them and see.
Also its easier to ignite a stoich mix :D
  • 1 year later...
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
