Hi I have up for sale is my toyota soarer, and below are some lists of what its got:
Electric Blue toyota soarer JZZ30 2.5L turbo
Rebuilt internal (still running in as i have only done approx. 200km since then)
car have just got a service 1 month ago with motul oil
18xxxxkm on the clock, well not really that km anymore due to engine has been rebuilt
Big single turbo conversion
Greddy/Trust TD06H-20G turbo
external wastegate
screamer pipe
oil catch return can
new NGK spark plugs
custom heat shield on turbo
K&N air intake with custom piping
"R154 5 speed manual conversion"!!!!!!!!
Microtech LTX-12s computer installed and tuned
Dyno tuned at 297.5hp @ wheels @ 14psi (Run in tune) as you can see the potential of this engine/turbo combination
Once its run-in with full tune, it should be able to do roughly 450hp@18~20psi with no problem.
*car was never boosted harder than 14, 15psi as I dont have a boost controller, it simply runs off the wastegate spring rate which is 14psi
18 inch Degeo slightly dished chrome wheels(in good condition)
2 new Nankang tires (in good nic)
wheel alignment and wheel balance done 1 week ago
twin 4 inch mufflers, 3 inch exhaust piping
custom front mount intercooler
custom body kit
rebuilt power steering pump
new electric window motor and assembly
custom blue/grey leather interior
custom DIY centre dash
JVC car mats
crystal look blue gear knob
Pioneer head-unit
turbo timer
Alpine ZR deep bass subwoofer
Alpine V12 amp
*things are removed from the car":(but do come with the sale)
GFB twin chamber blow off valve
Autogauge big shift light
Autogauge big monster tacho
HKS intercooler pipe piece
chrome gauge cup
rego til mid Oct
rwc upon deposit
Bads:
-few cracks and chips in the front spoiler and very minor crack in hood
-tear in under-bonnet lining
-synthetic blue leather insert in back seat damaged and foam underneath (due to left a leaking battery in the back seat)
*quoted around $200 redoing the damaged part on that seat*
-both seat belt buckles in the back needs replacing
-interior is in good condition but a few cracks wear and tear (common issue for soarer) here and there to be expected
in a 20 year old car.
-driver side head lights fallen a bit due to bolts broke off
-Dash LCD display works on and off, on and off, it works fine most of the time at night, but it seems lazy during the day
so, if you have always dreamed about having a big single turbo soarer in MANUAL, this is it! it wont disappoint!
Originally wanted $16,000 ( i know it might be a bit overpriced, well for the work that has been done on the car cost way more than
just $16,000, still) i have now dropped down to $11,000 to meet the market, so if you are in the market for a big hp manual soarer, please
do not hesitate to give me a call on 0433-350-626 or via TXT message if i cant take your calls due to i might be at work or even email at "[email protected]"
$11,000
thanks for your time reading!
Edited by sky_34
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
