Hi I have up for sale is my toyota soarer, and below are some lists of what its got:
Electric Blue toyota soarer JZZ30 2.5L turbo
Rebuilt internal (still running in as i have only done approx. 200km since then)
car have just got a service 1 month ago with motul oil
18xxxxkm on the clock, well not really that km anymore due to engine has been rebuilt
Big single turbo conversion
Greddy/Trust TD06H-20G turbo
external wastegate
screamer pipe
oil catch return can
new NGK spark plugs
custom heat shield on turbo
K&N air intake with custom piping
"R154 5 speed manual conversion"!!!!!!!!
Microtech LTX-12s computer installed and tuned
Dyno tuned at 297.5hp @ wheels @ 14psi (Run in tune) as you can see the potential of this engine/turbo combination
Once its run-in with full tune, it should be able to do roughly 450hp@18~20psi with no problem.
*car was never boosted harder than 14, 15psi as I dont have a boost controller, it simply runs off the wastegate spring rate which is 14psi
18 inch Degeo slightly dished chrome wheels(in good condition)
2 new Nankang tires (in good nic)
wheel alignment and wheel balance done 1 week ago
twin 4 inch mufflers, 3 inch exhaust piping
custom front mount intercooler
custom body kit
rebuilt power steering pump
new electric window motor and assembly
custom blue/grey leather interior
custom DIY centre dash
JVC car mats
crystal look blue gear knob
Pioneer head-unit
turbo timer
Alpine ZR deep bass subwoofer
Alpine V12 amp
*things are removed from the car":(but do come with the sale)
GFB twin chamber blow off valve
Autogauge big shift light
Autogauge big monster tacho
HKS intercooler pipe piece
chrome gauge cup
rego til mid Oct
rwc upon deposit
Bads:
-few cracks and chips in the front spoiler and very minor crack in hood
-tear in under-bonnet lining
-synthetic blue leather insert in back seat damaged and foam underneath (due to left a leaking battery in the back seat)
*quoted around $200 redoing the damaged part on that seat*
-both seat belt buckles in the back needs replacing
-interior is in good condition but a few cracks wear and tear (common issue for soarer) here and there to be expected
in a 20 year old car.
-driver side head lights fallen a bit due to bolts broke off
-Dash LCD display works on and off, on and off, it works fine most of the time at night, but it seems lazy during the day
so, if you have always dreamed about having a big single turbo soarer in MANUAL, this is it! it wont disappoint!
Originally wanted $16,000 ( i know it might be a bit overpriced, well for the work that has been done on the car cost way more than
just $16,000, still) i have now dropped down to $11,000 to meet the market, so if you are in the market for a big hp manual soarer, please
do not hesitate to give me a call on 0433-350-626 or via TXT message if i cant take your calls due to i might be at work or even email at "[email protected]"
$11,000
thanks for your time reading!
Edited by sky_34
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
