Reo bar, passenger headlight and passenger indicator sold.
drivers headlight still here.
Stock r32 rims also sold.
Edited by phat_man
Hey
Im after the front wheel arch plastics if you still have them?
Please pm if you do
cheers
Sorry mate, thought no one wanted them, so i threw them out.
EDIT: there actually still in the bin, when can you come and grab them?
Edited by phat_man
Price drop,
Brand new black avcr now 500
R32 brandnew uras handbrake shoes 200
Brand new kazama castor rods 250
Throw me an offer for the rest of the stuff...
Bump. Prices dropped...
Used:
R32 Gtst Nismo Coilovers $400 (absolutely awesome on the st) $350
R32/s13 rear camber arms upper and lower/traction rods (missing adjustment pins) $60 $40
R33 front pair LCA's $180 $150
r32 rear passenger LCA $60 $40
Standard r32 gtst side mount intercooler only with some piping $30
Standard r32 drivers headlight $100
r32 gtst Complete air con assy $80
Jasma exhuast $50
RAY's Wheels C-Ultras 2 x 17 x 8.5 +34 & 2 x 17 x 9.5 + 38 $350 with spacers (spacers worth over 150$)
off r32 gtst one wheel has buckle (~$50 to fix) but does not leak any air, great for drifting, they are really light, wont find any rims this light for this price.
Spacers are required to clear brake calipers. will need rubber for all 4.
2 x 25mm spacers 2 x 10mm spacers
Brand NEW BITS:
Kazama caster rods to suit r32's etc..... $260 I bought it for $300 never been used $250
Uras Handbrake shoes, never been used $220 i paid 250. $200
Apexi AVC-r boost controller in limited edition black never been used $550 i paid $660. $500
Edited by phat_man
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
