Hello,
I have purchased a pioneer headunit with "Hard wired remote input".
The R32 has two buttons on the dash; AM/FM and Tune
There is a black socket located on the radio loom.
As seen on the picture, the black socket has 2 wires. (i havent traced them back, but i'd assume they would be 1 for each button)
Does anyone know how to make this work with Pioneers Hard wired remote input?
It looks like a need a hard-wired remote control adapter?
Thanks
https://www.sau.com.au/forums/topic/372516-pioneer-hard-wired-remote-input/
According to this;
http://www.pac-audio.com/PACProductData/SWI-PS/1_Instructions/swi-ps_instructions_072309.pdf
The PAC SWI-PS can be used. However, each seperate radio button needs to be wired with resistors in parallel?
http://www.sonicelectronix.com/item_18027_PAC-SWI-PSv1-New-Version-of-SWI-PS.html
Is there a cheaper options available?
I would check the resistance of those. from memory they are 30 and 60 ohms. PAC would do it but I would move the ladder around a bit.
thanks for the input.
Perhaps you could investigate it on your r32 project :P
Any chance you got wiring diagram of the r32? Want to see if there is more than 1 wire coming off the factory radio buttons.
what you *could* do it use the values off the DIY site and mod the switch. that will net a neater solution. in my case the deck I have doesn't support them anyway and I intend to use them for something else.
there are two. a grey one and a org/blk. they both have a common return to the deck.
ah yep.
So;
Grey = Button 1
Org/blk = Button 2
And they share a common return to the deck? The headunit socket only appears to have 2 wires..(no third common return?)
sounds like a good idea. Looks like i'll be pursuing this adventure alone then!
